idlerboat 116 Posted April 10, 2014 Share Posted April 10, 2014 Due to impact the Northern QLD coast evening of the 11/4. Upgraded to Cat 5. For track map click.. http://www.bom.gov.au/products/IDQ65002.shtml Please note the sections highlighted in Red below and near bottom of bulletin. IDQ20018 TROPICAL CYCLONE TECHNICAL BULLETIN: AUSTRALIA - EASTERN REGION Issued by BRISBANE TROPICAL CYCLONE WARNING CENTRE at: 0656 UTC 10/04/2014 Name: Severe Tropical Cyclone Ita Identifier: 15U Data At: 0600 UTC Latitude: 12.6S Longitude: 147.0E Location Accuracy: within 5 nm [15 km] Movement Towards: west southwest [243 deg] Speed of Movement: 10 knots [18 km/h] Maximum 10-Minute Wind: 110 knots [205 km/h] Maximum 3-Second Wind Gust: 155 knots [285 km/h] Central Pressure: 935 hPa Radius of 34-knot winds NE quadrant: 90 nm [165 km] Radius of 34-knot winds SE quadrant: 100 nm [185 km] Radius of 34-knot winds SW quadrant: 100 nm [185 km] Radius of 34-knot winds NW quadrant: 90 nm [165 km] Radius of 48-knot winds NE quadrant: 50 nm [95 km] Radius of 48-knot winds SE quadrant: 50 nm [95 km] Radius of 48-knot winds SW quadrant: 50 nm [95 km] Radius of 48-knot winds NW quadrant: 50 nm [95 km] Radius of 64-knot winds: 30 nm [55 km] Radius of Maximum Winds: 15 nm [25 km] Dvorak Intensity Code: T6.5/6.5/D1.0/24HRS Pressure of outermost isobar: 1004 hPa Radius of outermost closed isobar: 150 nm [280 km] FORECAST DATA Date/Time : Location : Loc. Accuracy: Max Wind : Central Pressure [uTC] : degrees : nm [km]: knots[km/h]: hPa +06: 10/1200: 13.0S 146.3E: 020 [035]: 115 [215]: 928 +12: 10/1800: 13.7S 145.8E: 030 [055]: 120 [220]: 922 +18: 11/0000: 14.3S 145.4E: 045 [080]: 120 [220]: 922 +24: 11/0600: 14.9S 145.0E: 055 [105]: 120 [220]: 922 +36: 11/1800: 16.1S 144.5E: 075 [140]: 080 [150]: 964 +48: 12/0600: 17.2S 144.6E: 095 [175]: 035 [065]: 996 +60: 12/1800: 18.6S 145.5E: 115 [215]: 030 [055]: 1000 +72: 13/0600: 19.9S 147.4E: 135 [250]: 030 [055]: 1001 +96: 14/0600: 22.1S 152.6E: 180 [330]: 030 [055]: 1000 +120: 15/0600: 24.0S 156.4E: 265 [495]: 030 [055]: 998 REMARKS: Dvorak analysis of Severe Tropical Cyclone Ita was based on an eye pattern with a white surround and an added 0.5 for a dark grey eye combined with a white surround, giving a DT of 6.5. The average DT over the last 3 hours is 6.5 also. MET and PAT both give 6.0. Severe Tropical Cyclone Ita has intensified significantly today with the system now exhibiting a clear eye pattern on the recent satellite imagery. Deep convection has developed further near the inner core of the system with very cold cloud top temperatures now surrounding a well defined warm eye in the infrared satellite imagery. The system remains situated in a low vertical wind shear environment with sea surface temperatures greater than 28 degrees. CIMSS upper winds depict very good outflow above the system, which has allowed intensification to occur today. ADT is following this intensifying trend with a greater than a 100 knot system being analysed. Severe Tropical Cyclone Ita is being steered towards the west-southwest under the influence of a mid-level ridge extending across the central Coral Sea and up over the Solomon Islands. The system has been moving faster than forecast and quicker than any of the computer model guidance is indicating, so therefore some persistence has been paid to the short term forecast track. The mid-level ridge is expected to erode into Friday, which should then lead to the system developing a southwest track prior to landfall along the far north Queensland coast. Most of the global computer models are now indicating that the system will cross the far north Queensland coast late Friday between Cape Melville and Cooktown. Link to post Share on other sites
Black Panther 1,776 Posted April 10, 2014 Share Posted April 10, 2014 That's is a lot of wind Link to post Share on other sites
idlerboat 116 Posted April 10, 2014 Author Share Posted April 10, 2014 Yep BP...and due to the unusual behaviour, a few met people are suggesting extreme caution. Given the rough ride the met people get, if their predictions are over or under....they are in a bad place. Hence the additional notes..... It may hit the highest wind speeds in 30 years. ........but hey, our government is systematically stripping out a large proportion of science in the weather area, because after all...."what you dont know wont hurt you".... (The most recent a $ hundred mill, out of Antarctic research, sure not all will go from weather BUT with the suggestion that it be made back up by commercial interests....)It looks very bad for the Antarctic "wilderness concept" Link to post Share on other sites
