cep32 4 Posted July 31, 2015 Share Posted July 31, 2015 So for a plywood dinghy build over male mould, when do you remove the staples? I figure I will staple to just beyond 50mm from each join, fibreglass the joins with 100mm DB tape. The next bit has me worried. Can I then remove all of the staples from the bottom sections to the chine and glass that surface then once cured remove the staple from the sides and glass? Will the hull generally stay the right shape hugging the mould once the joins are done? Cheers, Chris Quote Link to post Share on other sites
Island Time 1,235 Posted August 1, 2015 Share Posted August 1, 2015 When my brother built his launch, they used plastic staples. Never have to take them out. Pretty cool... Quote Link to post Share on other sites
cep32 4 Posted August 1, 2015 Author Share Posted August 1, 2015 Both ideas sound great. Thanks. It is for a Javelin hull so the side panels rotate through a fair old angle. The only question I have is how to separate the hull from the mould if I have left the staples in or glued it? The glue I can imagine would separate as long as I'm not to generous with it but the staples will be acting in shear when pulling the hull off the mould? I think I need to build a 1/10th model to check all this stuff out. Quote Link to post Share on other sites
cep32 4 Posted August 4, 2015 Author Share Posted August 4, 2015 Cheers for that. The other option I have read about is using thin copper wire threaded through holes in the ply and twisted tight around the mould stringers. It was left in place until glassed over and then heated to melt the epoxy touching the copper so it could be slid free. Might be worth a try in the high stress areas. Quote Link to post Share on other sites
