cep32 4 Posted February 4, 2016 Share Posted February 4, 2016 Is it necessary to have the backing plate for trapeze lines? I found a reference to the 505 guys not bothering. I have a small hole already in the right place where the old line used to feed through and connect to a through bolt higher up the mast. I happen to have a couple of old short sections of wire with a hook swaged on the end so figured I could make the hole a little larger and hook directly into them. I would use dyneema for the rest of the length. Quote Link to post Share on other sites
Marshy 30 Posted February 5, 2016 Share Posted February 5, 2016 Yes. it will be like a can opener to a coke can otherwise... Quote Link to post Share on other sites
cep32 4 Posted February 5, 2016 Author Share Posted February 5, 2016 Bugger. Thanks for the info. Saved me from my own stupidity. Quote Link to post Share on other sites
white tornado 1 Posted February 8, 2016 Share Posted February 8, 2016 It depends on the wall thickness of the mast. Without backing plates, you will get a bit of wear, but if mast is reasonably thick walled, are unlikely to get splits. I have had my 2.5mm 1x19 wire Zephyr stays set up with hooks, no backing plates, and in 5 seasons of racing at least once a week, there has been about 2 mm of wear. The load on a Zephyr side stay is probably about the same as the average trapeze wire, but the trapeze wire will move round more, thus probably wearing faster. Quote Link to post Share on other sites
