eruptn 95 Posted January 30, 2017 Share Posted January 30, 2017 HiLooking for what I take to be a model 7020 regulator.Who supplies such.Thanks Tried to add pictures but doesn't seam to work. Quote Link to post Share on other sites
wheels 543 Posted January 30, 2017 Share Posted January 30, 2017 You will find them anywhere that sells LPG equipment, like fires, BBQ's and so on. Like M10, Bunnings, many Chandleries etc. They are just the common garden variety regulator. Quote Link to post Share on other sites
eruptn 95 Posted January 30, 2017 Author Share Posted January 30, 2017 Thanks Wheels, that's what I thought too, evidently there are pressure and flow ranges, straight through and right angle models ete etc. My existing (now broken one) is a long way from the BBQ spec. Does it matter for stove etc if the pressure is 'high' ? Quote Link to post Share on other sites
Farrari 4 Posted January 30, 2017 Share Posted January 30, 2017 I'm not sure if the regulator you are referring too has the feature, but you can also get regulators with an auto shutoff feature on excessive flow. The gas fitter that replaced mine also mentioned something about the seal type that was more appropriate for a marine environment. I previously had a standard garden variety LPG regulator like you would find on a BBQ. Quote Link to post Share on other sites
wheels 543 Posted January 31, 2017 Share Posted January 31, 2017 Does it matter for stove etc if the pressure is 'high' ? Simple answer, yes. The Flame will not "sit" properly or it could be the wrong colour and so on if the pressure is wrong. But the regs should all be the same. Of this type that is. There are different regs, but they will have different fittings so as you cannot attach to the wrong appliance. For the high pressure things like camp stoves etc. The standard BBQ one should work on your stove just fine. Quote Link to post Share on other sites
