Navman 5500 tracker cables
Dang it, I forgot to look. Righty, writing note to remind me right now.
I have most certainly got the unit and I am 99% sure there is a Power plug with it, but I wanted to confirm the lacking 1% before I said yeah I have one.
I originally bought the 5600 off a trademe seller, as a second unit. But when it arrived, I found a couple of important buttons were wouldn't work and you couldn't select certain functions. So I just left it in a box thinking one day I might pull it apart and fix it. Then IT sold me a flash B&G V7 and so I can't be bothered fixing the thing. So you are welcome to the lot and then if you ever wanted to, you could pull it apart and clean the contact pads and that should get it working again.
You better PM me your address where to send it.
Slight hickup sorry mate. The Power plug is not with the unit. I am pretty sure it is one the boat. In fact I am more sure I have it and know exactly where it is. The down side is that I won't be getting to the boat till Feb. Is that going to be a problem?
