vic008 17 Posted October 15, 2020 Share Posted October 15, 2020 12mm rope to wire(with a nice joining splice)but there is a splag(?)so will replace sometime. Do you just go straight to all spectre nowadays? Quote Link to post Share on other sites
CarpeDiem 431 Posted October 15, 2020 Share Posted October 15, 2020 45 minutes ago, vic008 said: 12mm rope to wire(with a nice joining splice)but there is a splag(?)so will replace sometime. Do you just go straight to all spectre nowadays? You should definitely get rid of the wire. You could downgrade the diameter considerably, saving cost on the line, but then you need to think about clutches and winches and handling which will increase cost. I made up a 5mm exposed core to a 10mm with sheath as a trial experiment for replacing my main halyard. It would be 5mm at the mast and 10mm at the clutch. Several end to end splices 5 to 6 to 8 with cover got me to 10mm at the clutch adding an 1mm insert should get 12mm at the clutch reef points. Quote Link to post Share on other sites
Black Panther 1,591 Posted October 15, 2020 Share Posted October 15, 2020 I just replaced the wire to rope. Cheaper and easier. Unless you are a full on racer no difference in performance Quote Link to post Share on other sites
