CarpeDiem 587 Posted November 6, 2021 Share Posted November 6, 2021 I have a Bronze sintered grounding plate on the hull for the SSB. Very similar, if not identical, to the smallest of these: The SSB has a wide/thin copper tie, 2" +/- wide x 1mm that connects to this. Why does it use a copper strip instead of just a wire? Can I use this as my EWOF marina AC earth? Thanks Quote Link to post Share on other sites
Island Time 1,358 Posted November 6, 2021 Share Posted November 6, 2021 Not for commercial survey. Most private vessels don't have ground plates. You don't have to have a ground plate for an ewof. Your ac ground should be connected to your DC ground (bus bar, engine, whatever it is) at ONE location only. IMO you should have a galvanic isolator in the AC ground, near the shorepower connection. This is only strongly advised in the regs. The SSB uses flat copper strap as it works better than a cable for RF grounds. Round cable is not great for a ground plane connection. This is NOT an electrical ground, but an RF ground, they are very different! 4 Quote Link to post Share on other sites
Neil 35 Posted January 12 Share Posted January 12 On 7/11/2021 at 11:41 AM, Island Time said: "You don't have to have a ground plate for an ewof. Your ac ground should be connected to your DC ground (bus bar, engine, whatever it is) at ONE location only. IMO you should have a galvanic isolator in the AC ground, near the shorepower connection. This is only strongly advised in the regs." @IslandTime Do you know if this is still true? My eWOF is about to expire and I'm being told I'll now need to have grounding plate. Is that a new thing? Quote Link to post Share on other sites
CarpeDiem 587 Posted January 12 Author Share Posted January 12 Bottom line... It depends on the inspector... The 2014 standard which seems to be the one most look to, states that a plate is required. It must be 0.1m2, min 5mm thick and min 20mm wide. However the 2008 standard is the one that's legally required to be adhered to. I don't have that standard and don't know what it says about equipotential bonding. I just did a mates in Westhaven in November, I used the saildrive for the bond, (with a galvanic isolator), and the inspector ewof'd it... Quote Link to post Share on other sites
Psyche 975 Posted January 12 Share Posted January 12 On 6/11/2021 at 9:06 PM, CarpeDiem said: The SSB has a wide/thin copper tie, 2" +/- wide x 1mm that connects to this. I'd just like to compliment you on your bilingual abilities, I too am reasonably fluent in imperial and own several whitworth spanners 3 Quote Link to post Share on other sites
aardvarkash10 1,187 Posted January 12 Share Posted January 12 3 hours ago, Psyche said: I'd just like to compliment you on your bilingual abilities, I too am reasonably fluent in imperial and own several whitworth spanners Bi-numeral, surely? A measurement worthy of Mr Bernard St Francis Whitworth-Socket (BSF to his friends), a famed (if apocryphal) bicycle mechanic of Sheffield. Later a Design Asst. for Norton motorcycles where his flexible approach to units of measurement led to the inclusion of minor but infuriating oil leaks as a standard feature in all crankcases and a wide range of gearboxes. 1 Quote Link to post Share on other sites
LBD 240 Posted January 12 Share Posted January 12 13 minutes ago, aardvarkash10 said: Bi-numeral, surely? And your pronouns are? 1 Quote Link to post Share on other sites
aardvarkash10 1,187 Posted January 13 Share Posted January 13 2 hours ago, LBD said: And your pronouns are? UNC/UNF Quote Link to post Share on other sites
Island Time 1,358 Posted January 17 Share Posted January 17 On 12/01/2026 at 3:59 PM, Neil said: @IslandTime Do you know if this is still true? My eWOF is about to expire and I'm being told I'll now need to have grounding plate. Is that a new thing? As CD said. Like all of it, up to the inspector. I don't have a plate, but my keel is connected to the bonding system, and is used as both a SSB ground plane, and ships ground. Bigger by a fair bit than a plate... 1 Quote Link to post Share on other sites
