2flit 52 Posted December 5, 2021 Share Posted December 5, 2021 Portends to be Made in New Zealand: Fluid Film Has anyone used this stuff and if so which one? http://www.fluidfilm.co.nz/ Fluid Film® is a lanolin based rust / corrosion preventive and lubricant that provides long term protection and lubrication for all metal surfaces. Fluid Film® locks out and displaces moisture while lubricating moving parts for extended periods of time. It will not be readily washed off with water, but creates a barrier of protection that continues to work even in the most corrosive of environments. Fluid Film® is the worldwide standard for corrosion protection and lubrication. Quote Link to post Share on other sites
Psyche 842 Posted December 9, 2021 Share Posted December 9, 2021 Have used lanocote and the other henley product, its all essential the same stuff- sheep grease but presented differently. Quote Link to post Share on other sites
