Guest Posted December 10, 2010 Share Posted December 10, 2010 Having a total brain fade and suddenly got paranoid. Repair just done to my boat using epoxy (West) which I'm 97% sure is a polyester built boat. Did I just cock-up or knot? Which statement is correct? 1 - It's OK to put epoxy onto old polyester but knot the other way around 2 - It's OK to put polyester onto Epoxy but knot the other way around. Link to post Share on other sites
morspeed 1 Posted December 10, 2010 Share Posted December 10, 2010 No#1 Good (as long as you remove any styrene wax off poly surface first) No#2 Bad Link to post Share on other sites
wheels 543 Posted December 10, 2010 Share Posted December 10, 2010 Yep your OK KM. Epoxy over Poly, not the otherway around. Epoxy will bond to cured Poly. Poly does not do well at sticking to anything. In fact, not even itself if the original is fully cured. Link to post Share on other sites
