Replacement for Walbro FRB -13 06416 Fuel Pump
Mine has died and no new ones coming in the country for quite a while.. The specs are 12v 7 psi  just used to pump fuel from tank up 1 metre to holding tank - dont suppose anyone has one they arent using or something that could do the same job ?
On 2/02/2023 at 10:48 AM, aardvarkash10 said:
I fitted two of these to replace the mechanical lift pump on SO.  One in operation, one spare.
Cheap as chips, works fine, perhaps a bit noisy if you are being picky..
https://www.trademe.co.nz/a/motors/car-parts-accessories/performance/fuel-systems/listing/3975467503
Looks quite small but at that price you could have another as back up ...Thanks for the link -will look into them
