SV Serengeti 0 Posted November 13, 2023 Share Posted November 13, 2023 Hi everyone, I am currently installing a Mastervolt Alpha Pro III external regulator to the stock 115A Mitsubishi alternator on my Volvo Penta D2 40. The alternator charges my starter battery (Endurant 680CCA). (For context: the rest of my set up includes 2 x 120Ah Relion lithium batteries that are charged from the starter battery via 2 x 30A Victron DC to DC charger. I decided against sending the alternator charge directly to the lithium batteries as the BMS does not have a way to warn the regulator before shutting down, and I don't wanna run the risk of losing my alternator) I believe I understand the basic wiring to make this work (see attached diagram, courtesy of James in England): I got my alternator modified by a professional auto electrician and I have the two field wires pocking out of the casing I must add a relay powered from the MDI (when the ignition comes on, wire nr7) between the battery and the RegOn terminal on the regulator (I understand this is where the voltage sense happens too) I also purchased the alternator temperature sensor so that the regulator can monitor the alternator temp I will be very conservative in the setting of the regulator to avoid frying the alternator (probably cap the output at 65% of the alternator capacity and lower the output based on alternator temperature thresholds) So I feel like I am ready to get started, but I have a question based on my exchange with a fellow boater James who has a very similar set up. Since I am losing the D+ connection on the alternator, I believe the Volvo Penta MDI will be unhappy and trigger low voltage alarms (again relying on James' experience here with a similar set up). Doers anyone know of a way to deal with the alarm? Whether to shut it down completely, or to provide the MDI what it needs? And also is there anything wrong you can see in that wiring diagram? Would you do anything differently? I have heard of a solution with an extra oil pressure switch and two relays, but I am getting out of my comfort zone here, so any help would be really appreciated note: small differences with the diagram attached my alternator modification got rid of the connection between the positive brush and the D terminal, so I would connect the Batt and Field terminals of the regulator directly to the two field wires pocking out I do not have a battery isolator in my setup, so I will directly go to the starter battery Quote Link to post Share on other sites
CarpeDiem 567 Posted November 13, 2023 Share Posted November 13, 2023 Pin 7 on ConnC of the mdi is not an ignition signal. You can pick up an ignition signal from the miltilink conn which the tachometer connects to. Pin 7 of ConnC is a dual purpose pin: 1. The mdi momentarily applies battery voltage to this pin to excite the alternator just after the engine starts; 2. The mdi then uses this pin to periodically sense the alternator output voltage and trigger a warning on the canbus if the voltage is outside a threshold (13.1v - 14.9v iirc). The stock alternators have a secondary small rectifier on the D+ for the purpose of isolating the B+ and detecting if the alternator is running. You could try connecting pin7 to b+ but I have no idea if that will create a parasitic load on your battery or if it will result in the mdi bitching that the voltage is high when it shouldn't be... e.g., before the engine starts. Adding an oil pressure switch is an interesting hack. The fact that you have even discovered this as an option leads me to believe that their could be issues with simply holding pin7 at 13.1v+... I feel compelled to add that the stock 115a alternators are incredibly excellent units with very capable regulators. They have built in remote voltage and temperature sensors and can run at full output for considerable lengths of time before backing off due to temperature. I suspect that you have well and truly weighed anchor and the ship has now set sail but a considerably better option, for anyone else reading this, is the VRC-200 from Nordkyn Design https://nordkyndesign.com/product/nordkyn-electronics-vrc-200-charge-reference-controller/ Quote Link to post Share on other sites
SV Serengeti 0 Posted November 13, 2023 Author Share Posted November 13, 2023 @CarpeDiem thanks for your thoughtful and detailed answer, I realise reading you that this part of my electrical refit is more complex than anticipated and that I haven't done enough research. It seems like there is no way around a "hack" to install the Mastervolt external regulator, which feels a bit silly. I did not know about the Nordkyn product which seems to be purposely designed around the constraints we face on a boat set up, wish I knew about it before. I guess I have modified my alternator already, so backing off now would be a rather costly exercise involving buying a new alternator and a new regulator, but maybe I should consider it? Quote Link to post Share on other sites
