banaari 27 Posted July 25, 2012 Share Posted July 25, 2012 For future reference, any good ideas on how to get those miniatures tyres on and off the sort of evil 4-inch rims used for dinghy beach trolleys, etc? Have almost lost sensation in hands due to long and hard-fought battle last night. Link to post Share on other sites
JK 28 Posted July 25, 2012 Share Posted July 25, 2012 I had the same problem after purchasing some new tubes. Ended up taking them back to the place I bought the tubes from & they put the tyres back on the rims in a couple of minutes at no charge. Link to post Share on other sites
Guest Posted July 25, 2012 Share Posted July 25, 2012 Tyre levers. Any cycle shop should sell them. Link to post Share on other sites
wheels 543 Posted July 25, 2012 Share Posted July 25, 2012 Deflate the tyre first Once deflated, squeeze the beads of the tyre together so that both beads sit in the centre of the rim. Their is a indent in the rim. That will then allow you to pull the tyre off centre to the rim and you can then pull one bead over the rim edge with a lever or spoon handle or... You will need two levers, one to lock the bead and the other to pry it over. A little detergent and water will help the lever slide against the rubber. Link to post Share on other sites
