vic008 17 Posted January 9, 2013 Share Posted January 9, 2013 Wooden onto wooden hull..2 1/2" bronze screws.Would use Sika but far too expensive- any alternatives please Link to post Share on other sites
Guest Posted January 9, 2013 Share Posted January 9, 2013 The best UV stabilised polymer adhesive/sealant you can afford. Sika's advantage as well as 3M's is very high tensile strength as an adhesive. Not so necessary in this case as long as the mating surfaces are true and the fastenings are adequate. I'm no boat builder though. Link to post Share on other sites
wheels 543 Posted January 9, 2013 Share Posted January 9, 2013 Do it properly, do it once. Sika or 3M might be expensive, but then again, nothing else will be much cheaper. You might be able to save on cost, but it will come back to bite you eventually. Link to post Share on other sites
