Guest Posted November 30, 2013 Share Posted November 30, 2013 Dr W - no one else has mentioned a problem, could it be at your end? Link to post Share on other sites
DrWatson 382 Posted November 30, 2013 Author Share Posted November 30, 2013 Possible, I am in Taipei in the weirdest Hotel... Link to post Share on other sites
Kestrahl 10 Posted December 2, 2013 Share Posted December 2, 2013 Depends on how big and heavy the sail is you intend on making? If you will have problems with this size machine. Seaming shouldn't be to much of a problem. When you start webbing rings on the corners you might start seeing the sparks fly. Your average sail built professionally will likely go through 3 different machines. what's wrong today? Site is timing me out every 3 minutes! anyway...cheaper here... http://www.sailrite.com/Ultrafeed-LSZ-1 ... pmRm8TkuGc What's a special technique for doing larger sails on a machine like this? I imagine that you need to tape all your seams first and therefore construct the sail to check the hang etc, and then you'd need to squeeze minimum half your sail through under the arm to stitch the taped seams, no? Link to post Share on other sites
Guest Posted December 2, 2013 Share Posted December 2, 2013 As Booboo said, Adler 98 all the way can handle pretty much anything you could throw at it, plenty of parts around and will go all day everyday if need be. Come up now and again on Trademe but dont usally last long though. Cheers, SS Link to post Share on other sites
