johnMi 2 Posted February 10, 2010 Author Share Posted February 10, 2010 Thanks all for your help, and after listening to your advice, have bitten the bullet and ordered a new section. Wheels, thanks for your advice and offer. GregW, a question then, I think the stronger chainplate thing is irrelevant. It would have been designed for the maximum possible load before capsizing. I am not altering the stability, so no more stress will be added. what do you think? Samin, I am adding another halyard so might put on a barber hauler on to make it masthead if necessary. At th moment only have one halyard for both screacher and genniker Link to post Share on other sites
johnMi 2 Posted February 10, 2010 Author Share Posted February 10, 2010 Samin, I see capricorn is about 700 odd kg, similar to putiki express. your mast is about 11 metres, similar to what i will have. what size was your genniker, and main, do you know? If I can get to capricorn's calibre I'll be more than happy. Link to post Share on other sites
GregW 23 Posted February 10, 2010 Share Posted February 10, 2010 GregW, a question then, I think the stronger chainplate thing is irrelevant. It would have been designed for the maximum possible load before capsizing. I am not altering the stability, so no more stress will be added. what do you think? Hi John, It may well be irrelevant, I have no idea. You were talking about replicating a larger factory rig therefore, to me, it would seem prudent to check the spec of the attachment points. Link to post Share on other sites
samin 0 Posted February 11, 2010 Share Posted February 11, 2010 Samin, I see capricorn is about 700 odd kg, similar to putiki express. your mast is about 11 metres, similar to what i will have. what size was your genniker, and main, do you know?If I can get to capricorn's calibre I'll be more than happy. Ill take that as a complement, thanks Capricorns main is approx 27m2 which is the same size as Creepy Crawlers new main (he has shorter boom and longer mast now) Masthead Gennaker is around 78m2 Link to post Share on other sites
