Hi - I would like to hear from anyone using Aquacote -
Have you got a boat now???  "The chemistry behind the brand segregates a repulsion between water and non polar substances. In essence, it attracts and repels at the same time, creating a friction that will clean your boat of biofilm, oil and plankton as you're going through the water. " Oh dear, sounds like postmodernism again and there were other silly unscientific claims. And if you are going to slag off your opponents you should at least spell their produce name properly (linbide not limbide). The website contradicts itself too. Says you can wipe off with a finger with no pressure. Later says you need a plastic scraper. Later says low pressure hose was needed.
But my mind is open and I'm keen to hear too from some real people who've tried it.
