eruptn 110 Posted February 25, 2021 Share Posted February 25, 2021 Amongst other maintenance I'm wanting to do the zinc on the saildrive (SD20). I have Bri-Ski folding prop, got the blades off ok. Got the lock bolt out as well .. was going so well. I have a socket on the retaining nut and all I can do is turn the motor over. So jambed that up and now all I'm doing is moving the whole saildrive a inch or two, lots of elasticity in the system. How does one remove the elasticity to get the nut undone ? Quote Link to post Share on other sites
w44vi 18 Posted February 25, 2021 Share Posted February 25, 2021 I put a steel rod thru the pin holes so you can pull aganst each other, when you put the hub back on make sure you put a good amout of marine grease on the spline Quote Link to post Share on other sites
DoT 31 Posted February 27, 2021 Share Posted February 27, 2021 Same with me - rod (eg: very large screw driver) through the pin holes. And a big bar on the socket. On my drive the securing nut is castellated and there is a split pin to remove first. This stops me from trying to over tighten the nut when remounting the prop. Quote Link to post Share on other sites
