Guest Posted September 9, 2012 Share Posted September 9, 2012 A question What is the difference between WD 40 and CRC6-66? And where would you use them and where would you not use them? Link to post Share on other sites
Guest Posted September 9, 2012 Share Posted September 9, 2012 someone wake up wheels, the tins don't say whats in them other than the 66 says new improved formula that resists drying out Link to post Share on other sites
wheels 544 Posted September 9, 2012 Share Posted September 9, 2012 No wonder I couldn't sleep. I had this buzzing in my head. Someone was calling me I will keep this all simple so you nerds, don't go getting all nerdy on me and telling me I have left stuff out or whatever. CRC666 is based on Paraffin oil (which is basically Kerosene) and WD40 is based on Baby oil and Vasoline. CRC has a Saltwater protection rating of 65hrs. WD40 has several rather long worded additives, all belonging to the Alkane family. They are used as Solvent, "Antifreeze" so it will remain liquid in temps below freezing, Water repellant(being hydrocarbons)hydrogen atoms hold no charge, so thus will not attract to water molecules and thus acts as a repellant) and one other Alkane that has an affinity to metal. So in a nutshell, WD40 remains more of an oil film and CRC remains more of a waxy film. Does one work better than the other?? I have no clue really. I think the question is what are you wanting to do mostly Squid?? Link to post Share on other sites
Guest Posted September 9, 2012 Share Posted September 9, 2012 WD40 can be used to fire a diesel engine (the same way as ether but much more gentle) but CRC can't. Link to post Share on other sites
Guest Posted September 9, 2012 Share Posted September 9, 2012 WD40 is an American secret agent. I've used, in the past, that lanolin product. It is brilliant. Leaves a thick film, but holds back corrosion a lot better than the other products in lieu of proper maintenance.l As a lube it OK too. Link to post Share on other sites
John B 121 Posted September 9, 2012 Share Posted September 9, 2012 You buy CRC because they supplied the water taxis at Russell in the coastal classic for countless years at no cost to race crews. They only stopped when compliance made it more difficult than it should be. Link to post Share on other sites
chic014 0 Posted September 9, 2012 Share Posted September 9, 2012 Which one supports sailing in NZ? Link to post Share on other sites
Guest Posted September 9, 2012 Share Posted September 9, 2012 Which one supports sailing in NZ? A product called SPARC. It lubicates the "Upper echelon" of sailors in NZ and it is expensive! CRC supports fishing in NZ WD40...? Link to post Share on other sites
chic014 0 Posted September 9, 2012 Share Posted September 9, 2012 I think you'll find CRC supports sailing..... http://bayofislandssailingweek.org.nz/ http://richmondyc.org.nz/ Link to post Share on other sites
John B 121 Posted September 9, 2012 Share Posted September 9, 2012 Exactly. Link to post Share on other sites
Kaihe Atamai 2 Posted September 9, 2012 Share Posted September 9, 2012 Which one supports sailing in NZ? CRC is and has been a generous supporter of sailboat racing in Auckland via RichmondYC! Link to post Share on other sites
