Sign in to follow this
Solo trans tasman
I can't stall my AP's, the tiller will break long before I reach that point. That is something I'm planning changing. I can just see a slight movement on the power sucking meter when the AP is really pushing, which is very rarely.
Yours sucks 3amp unloaded, holy crap that's massive. The book reckons mine uses 40 millis, 90 with all the lights on in super bright mode. I'm beginning to see why some of you lot need to tow Huntly power station around behind you.
And what's this crazy talk about it knot being calm? It will be for me, I paid extra for the 'Premium Weather Package' where it's always 18-20 kts over the aft 1/4 with a nice large following swell that is easily surf able. 22 degrees during the day 18 at night. :thumbup:
Share this post
Yep, the weather might be perfect!!! :lol:
Most of the bigger tiller pilots cannot output more than about 80kg of thrust. But that is like standing on the tiller, although with a shorter lever, as the tiller pilot is not normally connected at the end of the tiller. Give yours some resistance by hand, and see what the load does to the amps...
My AP- maybe I was not clear enough - 3amps while moving an unloaded rudder. On, but not moving similar to yours - less than 0.5 amps!! The better the boat balance, the less power it uses...
I run 2x 36 watt solar panels, and a wind Gen, and I still consume about 150 Amp/hrs per day on a light air passage. That is with AP, Fridge, AIS, Radar, Laptop, Sonar, Instruments, Nav Lights, etc all being used. Its about 1 engine hour every 12 hours (one in morning one at night) if there is not much wind over the deck for the wind gen. I ran the engine for an hour a day in the solo tasman - for the freezer - I dont recall having to run it at all for the batts. Had enough wind! :D
Share this post
I know what you mean about the AP and loads. But you do have a lot larger unit driving a lot heavier steering system on a lot heavier boat.
Holy crap look at that power sucking list, it's huge. I couldn't physically fit all that on my boat let alone power it all :lol:
Share this post
HI KM
I have two SPx 5 Tiller arm Pilots 2.5a is peak draw at the dock no load. The circs are fused @ 10A, so in big waves it could be drawing that amount, a lot. These motors are used commonly on Mini Transat boats, and are as good as I could afford. I have a cheapo A/Helm 2000, as emergency, which draws a lot less. But its a toy compared to the proper units, and have been thru several cheapo versions on previous offshore trips, so it my last resort back-up. Power will be an issue, and I hope to try to do the 500 miles this side of Xmas to see how I go with the power, and maybe might need to get a Windgen, which with runners and backstays might be an issue.
Share this post
Oh so you have a huge unit also RL.
I'm running ST1000's and 2000's. If each one lasts 48hrs I'll be leaving with 8-10 days worth. If I'm still knot there by then it looks like some long sits with tiller in hand.
The SPX is nice but goes against some of what I want to achieve. Which is the same reason I won't have a HF set, aren't fitting a chart plotter (unless it's a by product of the AIS as it maybe), won't be having 23 sails, won't be wired into 24/7/366 communication systems and lots of that fluff. It's that extreme I'm even, some may need to look away now, taking a book made of paper rather than a iThing...... gosh shock horror :lol:
Share this post
For power I have been thinking about a wind gen but have been put off. I think the engine will keep the batteries full.
What do you want to know about me. I could use some good ideas myself.
Share this post
What other power generation do you have or are you considering?
What about Auto pilots, what's your plans there?
Share this post
I have put in a brand new Raymarine SPX 5 Plus tiller pilot. Well over sized for my yacht but means it can handle it. I have it integrated with my wing gear and my chart plotter which means it will steer to the wind!
At the moment i have just the engine and two small 40w solar panels but i don't think this is enough. I am thinking about putting in another house battery in parallel with the other. After replacing the starter battery this should help.
Any ideas???
I'm sure like me there are two or three of us that have to do 1000 miles for our yachts? i was thinking of going to the kermadecs and back in November if there are other yachts out there that need to do the same we could have a little test race!
Share this post
thought the qualifier was 500 .I was going to sail out to the international date line and back aftrer our Xmas cruise.
Share this post
