Changed 10 Posted November 8, 2014 Share Posted November 8, 2014 Was wondering if anyone has expert knowledge with this product. can I mix some of the clear finish with the undercoat to get a slight shine? Quote Link to post Share on other sites
wheels 544 Posted November 8, 2014 Share Posted November 8, 2014 Same as MB. Personally I would not take the risk. Just because something is Urathane or Epoxy means nothing to compatibility. There are so many variations. It would be horrible to coat the whatever you are painting and then find it never actually fully cures or creates the long lasting finish it should have, which is the reason you use such a finish in the first place. Or even worse, have it react or not go of at all and then you are left with a mess to get off. Because such coatings harden and cure by Chemical reaction, adding something it was never intended to have added to it, can affect that reaction. As MB said, you need to talk to the Manufacturer and if they have Tech support, they might tell you, bit chances are, they won't take such a risk of stepping outside the boundaries. Unless it is a small company and you get to talk directly to the Chemist, maybe, just maybe he might tell you. Quote Link to post Share on other sites
Optional Extra 0 Posted November 8, 2014 Share Posted November 8, 2014 Was wondering if anyone has expert knowledge with this product. can I mix some of the clear finish with the undercoat to get a slight shine? Yes add some gloss to the undercoat and you get a more glossy finish. Remember to add a small amount of thinners If using it outside remember to use the UV coating over the top as over time it will break down otherwise. Durepox is awesome stuff, I use it everywhere on the boat Quote Link to post Share on other sites
wheels 544 Posted November 8, 2014 Share Posted November 8, 2014 Must try some of this stuff. Just read a heap about it and it sounds almost too good to be true. The Technical specs state that you can add as you have asked and as OE has said. http://www.durepox.com.au/products/tdss ... 20TDS1.pdf See Note: on Pager two. Quote Link to post Share on other sites
Changed 10 Posted November 9, 2014 Author Share Posted November 9, 2014 Yep Fun and games gave good advice. job done. The clear and the colours use the same hardener. alternatively the clear can be sprayed over the colour to give a full gloss finish. Quote Link to post Share on other sites
Clipper 375 Posted November 6, 2016 Share Posted November 6, 2016 Old thread i know, but wondering if you can roll on durepox? Want to paint my centreboards with something hard. Quote Link to post Share on other sites
Bogan 8 Posted November 6, 2016 Share Posted November 6, 2016 I have rolled it on (white on my transom board), and brushed it on (clear gloss on a floor board). It's hard to get a completely smooth finish but the foam roller did a pretty good job. You get pretty thin coats and use up a roller head with every coat. Quote Link to post Share on other sites
wheels 544 Posted November 6, 2016 Share Posted November 6, 2016 You can break it down a little with the thinners to make it easier to roll and tip off.It is a coating that is supposed to continue to flow out smooth as it goes off. I have just painted a Drag car in the stuff, because the owner wanted something hard. He sure got that. It is hard as hobnails.In saying that, there are other coatings that are just as hard and perhaps easier to apply. Quote Link to post Share on other sites
Clipper 375 Posted November 7, 2016 Share Posted November 7, 2016 [quote name="wheels" post="174741" timestamp="1478475235 In saying that, there are other coatings that are just as hard and perhaps easier to apply. Such as? Quote Link to post Share on other sites
wheels 544 Posted November 7, 2016 Share Posted November 7, 2016 Clipper, I just re read you post. I didn't pickup on the centre boards part. Durapox would be a good call for that. Durapox is not pure epoxy. It's an Epoxy Urathane mix and that is very important for outdoor use as pure Eopxies Chalk in UV.Hempels also do several Epoxy coatings. I have just used one particular Hempel product on my workshop floor and it is absolutely amazingly hard wearing and was very well priced. Quote Link to post Share on other sites
Guest fng Posted November 12, 2016 Share Posted November 12, 2016 They do an accelerator to go with it, this seems to make the durapox dry a lot harder ( definitely harder to sand ), so its what i add when wanting more hardness for the likes of foils and high traffic areas. They did a lot of testing of it way back when i was at Cooksons - we did engine bays and even fuel tanks with it. Not too sure how it would go with bio-diesel due to the methanol content, mind you not many paint manufacturers would warrant their paints with that either I use it as a preferred primer for nearly everything. Quote Link to post Share on other sites
