Refrigeration Condenser
strath
Hi
Can somebody advise where I can get a replacement condenser made, other than Fridgetech in Albany ???
It is to replace a condenser out of a one tonner and is possibly over thirty years old.
The old existing one is mounted under the motor in the stainless drip tray.
Due to the restriction in space etc. in and around the motor, it would be far easier to replace the unit with one the same or similar size and if possible the same refrigeration hose connection positions etc.
The main tube is 65mm dia and 680mm long.
If you haven't found one, and can wait a few months, I pretty sure I have a mint one of these in a lockup in Auckland. I'm currently in Sydney and wont be back in Akl for a month or two hence I cant get at it at the mo
