drbob 0 Posted May 14, 2016 Share Posted May 14, 2016 The 'ship is going to get a bottom birthday and while I'm at it I'm thinking to tidy up the rudder and try and get rid of the hummmmm. The rudder is still the original plank, but now stood up perpendicular (rather than following transom line). So I have to cut off the bottom to level with waterline, but I'd like to make sure the profile is good too. What's the appropriate profile for a rudder on a turbo'd 930? Quote Link to post Share on other sites
erice 732 Posted May 14, 2016 Share Posted May 14, 2016 little known fact U2's album was written when adam clayton was experiencing problems with his stock rudder Helter Skelter being about the difficulty helming downwind at speed and under masthead gennaker Desire when he decided to change from stock Silver And Gold about the cost + I Still Haven't Found What I'm Looking For when he finally gave up changing naca profiles Quote Link to post Share on other sites
drbob 0 Posted May 14, 2016 Author Share Posted May 14, 2016 frikkin brilliant! Quote Link to post Share on other sites
armchairadmiral 411 Posted May 14, 2016 Share Posted May 14, 2016 Why does the rudder bottom have to be level with the waterline ? Naca sections are obvious....why reinvent the wheel and rediscover fire ? Quote Link to post Share on other sites
ballystick 74 Posted May 14, 2016 Share Posted May 14, 2016 Stu built a new rudder when he had Ballistic, I think he is All Fired Up. If you search under foam profiles then it can be found but the photos haven't come through, his rudder set up was different to normal 930s though. Quote Link to post Share on other sites
all fired up 6 Posted May 15, 2016 Share Posted May 15, 2016 Yes I did build a new rudder for Ballistic. The technical overview and guidance was done by board member fng. a.f.u Quote Link to post Share on other sites
Herdy 0 Posted May 15, 2016 Share Posted May 15, 2016 I have a copy of some 930 plans at home with has a rudder profile on it. I can hunt them out for you. May be a starting point. Quote Link to post Share on other sites
drbob 0 Posted May 16, 2016 Author Share Posted May 16, 2016 I have a copy of some 930 plans at home with has a rudder profile on it. I can hunt them out for you. May be a starting point. that would be a good start thanks - I can at least get the barn door fair to original, eh Quote Link to post Share on other sites
Guest fng Posted May 20, 2016 Share Posted May 20, 2016 Have got 930 drawings Did the new class compliant rudder for hotdogger a while back As long have a afu's profiles You can contact me through here apparently, I do get emails from members Quote Link to post Share on other sites
drbob 0 Posted May 22, 2016 Author Share Posted May 22, 2016 fng I think your message box is full, or settings are preventing messages Quote Link to post Share on other sites
