ex TL systems 63 Posted May 22, 2016 Share Posted May 22, 2016 hi i have an old air x wind gen that only came with 1 blade , after extensive research i have concluded that it would be better to have 3 blades, maybe someone has some old blades around as I would like to see if it is working before investing in a new set? 0210764371 Quote Link to post Share on other sites
erice 732 Posted May 22, 2016 Share Posted May 22, 2016 have a dead rutland 503 loose bearings meant the rotor magnets ate the stator windings the rotor head would be half? the size of an air x pm if you want to pick up for a play Quote Link to post Share on other sites
Island Time 1,239 Posted May 22, 2016 Share Posted May 22, 2016 Extl, I have a spare set of the standard blades - you're welcome to borrow them for a test, but I don't want to sell them. If it goes, I'd be happy to do you a deal on some of the silent wind blue blades for it. Makes them MUCH quieter and work better, but they aren't cheap. If you come up to gulf harbour to collect them, I can show you both types, so you can see and hear the difference, and make up your own mind. Quote Link to post Share on other sites
ex TL systems 63 Posted May 22, 2016 Author Share Posted May 22, 2016 hi island time I will be up in Akl on Tuesday but probably won,t have time to get to Gulf Harbour , I can probably test the unit by powering up with a drill and then if it goes will get a price for the blades , thanks. Quote Link to post Share on other sites
