Guest 000 Posted January 8, 2017 Share Posted January 8, 2017 My little 2hp Suzuki is running pretty well after a recent rebuild, but at heading towards peak revs it gets a bit hesitant and unable to produce the last little bit of power. The needle jet has three settings by which you can make the fuel mixture a bit richer or leaner, but how do you know which you should do. When the motor starts to hesitate, it doesn't blow any smoke and the plug is clean. Quote Link to post Share on other sites
erice 732 Posted January 8, 2017 Share Posted January 8, 2017 no smoke, clean plug try the richer setting first 1 Quote Link to post Share on other sites
Guest 000 Posted January 8, 2017 Share Posted January 8, 2017 Yep, kinda thinking the same. Now just need to find a quiet Bay to do the job. Lots of tiny spring loaded parts just itching to shoot over the side... Quote Link to post Share on other sites
jim s 34 Posted January 8, 2017 Share Posted January 8, 2017 An easy way to find out is to get it to the point of hesitation and turn off the fuel - if it goes better just before it runs out of gas then it was too rich but if it just gets worse then probably it was too lean. you need to close the throttle and turn the fuel back on fairly swiftly if it indicates too lean as we don't want to badger a lean two stroke... there are other possibilities but turning of the fuel will narrow the field down a lot Quote Link to post Share on other sites
Guest 000 Posted January 9, 2017 Share Posted January 9, 2017 Thank you Jim s. Now that is a handy bit of information ???? Quote Link to post Share on other sites
mattm 98 Posted January 9, 2017 Share Posted January 9, 2017 Would applying a little choke at the point of hesitation achieve the same test? Making it a little richer to see if that helps? Quote Link to post Share on other sites
jim s 34 Posted January 10, 2017 Share Posted January 10, 2017 Yes that would work too although if it ran well with the choke say half closed you might be getting only two ponypower - so long as that didn't affect your judgement. certainly you would hear the little engine improve or not and it would help diagnose it. Quote Link to post Share on other sites
Guest 000 Posted January 16, 2017 Share Posted January 16, 2017 OK, done it in line with mattm's post which confirmed that the motor was running a bit lean. Adjusted the carburetor needle valve and all good now. If only I could make myself a bit richer so easily. Thanks to all for the good advice. Quote Link to post Share on other sites
