rossd 16 Posted January 20, 2020 Share Posted January 20, 2020 Am going to install a couple of lee cloths using the fabric from camp stretchers, the sprung steel support ones. Was thinking of using a 15 or 20 mm dowel through the hem already there and attaching rope around that and through the cutouts in fabric. Internet seems a bit divided on length, either from knees to shoulders or full bunk length? Also the height, some say 18 inches which seems lot to me , would not 300mm be OK? Is it going to work? Just for overnight coastal use nothing to dramatic weather wise I hope. Quote Link to post Share on other sites
Black Panther 1,587 Posted January 20, 2020 Share Posted January 20, 2020 Dont go full length. Need air circulation or your crew will be very seasick. Quote Link to post Share on other sites
Steve Pope 243 Posted January 20, 2020 Share Posted January 20, 2020 Shoulders to just past the hips, allow for longer folk, We used a strong netting fabric allows for air circulation, Eye bolt at each end with 1 x 5mm nylon cord picking up 4 equal points and can be tied of once you are in it, and loosened / untied when you get out. easy peasy. Quote Link to post Share on other sites
rossd 16 Posted January 20, 2020 Author Share Posted January 20, 2020 Thanks for that, I will cut it down a bit and flag the dowel , just a hassle to store. Quote Link to post Share on other sites
idlerboat 116 Posted January 23, 2020 Share Posted January 23, 2020 I use the large plastic "squeeze to undo clips. One at each end and one in the middle. This allows you to have the middle and foot end clipped and the head end undone for easier access but still holding everything in in a rolling sea .. And seems to be more comfortable for those prone to "the ills". When its very bumpy you clip the head end one up. The width of an average persons shoulders is as high as you ever need to go..to fall out over that means you have put the mast under water ! Quote Link to post Share on other sites
