Bittersweet89 0 Posted August 26, 2021 Share Posted August 26, 2021 In desperate need of a set of eastery 30 windows, aft, forward, port, starboard, need them all lol Quote Link to post Share on other sites
mattm 98 Posted August 27, 2021 Share Posted August 27, 2021 I’m in the process of replacing windows on a Noelex. I have taken them all out, and will take them to a place that deals with Perspex and have them cut a new set, then I will refit - using the right type of sealant, or possibly tape (fault with the existing windows - the wrong sealant was used and it let go and they all leaked) If your not in a position to have all the windows out for several days, maybe buy a sheet of Perspex, remove, cut and refit one at a time yourself? Unless your windows are glass, then I assumed you’d need to remove them and take them to a glass place to be copied? Quote Link to post Share on other sites
Island Time 1,235 Posted August 27, 2021 Share Posted August 27, 2021 They are not expensive. Acrylic Creations is who I use. Search this site, plenty of info already here. Quote Link to post Share on other sites
Bittersweet89 0 Posted August 27, 2021 Author Share Posted August 27, 2021 Cheers, thanks for that, just looking for a used set but may be better going new, what thickness is good for strength, possibly offshore? Quote Link to post Share on other sites
Island Time 1,235 Posted August 27, 2021 Share Posted August 27, 2021 Cannot answer that question without knowing window size, overlap on frame etc. Same as original is likely fine. No screws or bolts! Thats what leaks, fill and fair the frame, then glue the new windows in. The new adhesives are stronger than the old bolts... and dont leak! 1 Quote Link to post Share on other sites
mattm 98 Posted August 27, 2021 Share Posted August 27, 2021 2 hours ago, Bittersweet89 said: Cheers, thanks for that, just looking for a used set but may be better going new, what thickness is good for strength, possibly offshore? I doubt many people are pulling windows out of Easterly 30’s (or any other design) that are in a state you’d want to be re-using them. Especially, as IT says, as they are not that dare new. Quote Link to post Share on other sites
Bittersweet89 0 Posted August 28, 2021 Author Share Posted August 28, 2021 Cheers for that! Quote Link to post Share on other sites
