funlovincriminal 218 Posted October 31, 2021 Share Posted October 31, 2021 Now the wobbly bit is back in the hole I guess I'd better seal/chock it. What's your preferred method/product? Spartite? Silicone and wedges? Some other wonder product? Should I do it before or after tensioning/bending the rig? While I'm at it, what's the best stuff to use to seal on top of the mast dam? Cheers Quote Link to post Share on other sites
Island Time 1,354 Posted October 31, 2021 Share Posted October 31, 2021 I like Spartite. Used that when I put the rig back in IT, and have used on some customer's boats as well. If you wax the collar, then the rig can be removed and replaced without removing the spartite. Or it can be cut. But it gives good support for the rig over a wide area, and does not move or leak. I have a spare can, enough for your boat if you wish. Make an offer, I bought too much! Quote Link to post Share on other sites
funlovincriminal 218 Posted October 31, 2021 Author Share Posted October 31, 2021 I waxed rig and collar before it went in. Should probably clean the mast wax off? Quote Link to post Share on other sites
Island Time 1,354 Posted October 31, 2021 Share Posted October 31, 2021 Yeah, I would, then the spartite comes out with the rig - UNLESS then collar is not smooth, or is stepped at all. If that's the case, then don't use wax, and just cut it off if you need to remove the rig again. Quote Link to post Share on other sites
Cameron 110 Posted November 1, 2021 Share Posted November 1, 2021 Have a chat to Steve Ashley http://www.riggingshop.co.nz/ After he sealed the mast collar it's the most water tight it's ever been. He didn't seem to be a big fan of Spartite. For inside the mast... A block of foam cut tight to fit then rammed up the mast to just below the lowest exit point. Then pourable silicon over the top until flush. It's good if you can heel the boat toward the side opposite the exit hole so the silicon sets on an angle and the lowest point is at the exit. Quote Link to post Share on other sites
