CarpeDiem 575 Posted February 22, 2022 Share Posted February 22, 2022 Just sits there at 0%... Have tried 3 times over several weeks... Pops up a message saying update available, but stays at 0% Any ideas anyone? Quote Link to post Share on other sites
Island Time 1,347 Posted February 22, 2022 Share Posted February 22, 2022 As Above usually works. If not, call Navico on 08004628426 and they will talk you through other options. 1 Quote Link to post Share on other sites
CarpeDiem 575 Posted March 13, 2022 Author Share Posted March 13, 2022 Can the Zeus2 act as a nmea terminator? I can disconnect everything except wind gear as I only have one terminator. And the upgrade still fails. Quote Link to post Share on other sites
Psyche 913 Posted March 13, 2022 Share Posted March 13, 2022 are you doing it via sd card? Quote Link to post Share on other sites
Island Time 1,347 Posted March 13, 2022 Share Posted March 13, 2022 4 hours ago, CarpeDiem said: Can the Zeus2 act as a nmea terminator? I can disconnect everything except wind gear as I only have one terminator. And the upgrade still fails. No. THE Zeus 2 is just a device, same as any other. If you can't do it, see my post above, navico can fo it at Albany, or I can do it if you can get it to me. Quote Link to post Share on other sites
CarpeDiem 575 Posted March 13, 2022 Author Share Posted March 13, 2022 I got a terminator (thanks Bradz) and still can't get it to upgrade with just the Zeus2 and p9 on the bus. Just sits at 0%. Will call Navico tomorrow,and reach out to you IT if they are unhelpful... Thanks all. Quote Link to post Share on other sites
Island Time 1,347 Posted March 13, 2022 Share Posted March 13, 2022 2 terminators, right? One on each end of the bus, and the 2 devices on Ts and drop cables, plus the one for bus power.... Quote Link to post Share on other sites
CarpeDiem 575 Posted March 13, 2022 Author Share Posted March 13, 2022 25 minutes ago, Island Time said: 2 terminators, right? One on each end of the bus, and the 2 devices on Ts and drop cables, plus the one for bus power.... Thanks IT. Yep. I have a 4 port bus. Connected to one end of the 4port bus is a terminator. (thanks Bradz) this usually has the wind sensor. Connected to the other end of the 4port bus is a backbone cable which has two tees and a terminator on the very end of it. It runs from about the engine to parallel with the mast. Power, zeus, p9 are connected directly to the 4 port bus with their drop cables There's nothing connected to the two tees at the end of the backbone extender, these usually have the p9 and dst800 on them... I had planned to take terminator from the backbone extender and connect it to the four port bus to eliminate the extender cable but turns out the male/female is incompatible... Looking at network device list on the Zeus, it shows the p9 and the Zeus (x4) only so it seems to see what it should. Quote Link to post Share on other sites
CarpeDiem 575 Posted March 13, 2022 Author Share Posted March 13, 2022 2 hours ago, Psyche said: are you doing it via sd card? No. The Zeus2 has Internet, at some point in the last few months it has detected the update and every time I turn it on it advises of an upgrade to be performed.. Quote Link to post Share on other sites
Island Time 1,347 Posted March 13, 2022 Share Posted March 13, 2022 Trash the update file and download again...also make certain the Zeus 2 is up to date 1st. Quote Link to post Share on other sites
CarpeDiem 575 Posted March 14, 2022 Author Share Posted March 14, 2022 Used the sd card method and it upgraded. Seems to have lost it's calibration. What's the difference between "auto" and "auto lock" in the calibration menu? Quote Link to post Share on other sites
