Paul Nicol 1 Posted April 20, 2025 Share Posted April 20, 2025 Has anyone had to replace the sails on nova 28 and what was the approx cost Quote Link to post Share on other sites
Frank 236 Posted April 21, 2025 Share Posted April 21, 2025 I paid $3250 for a new Roller Furling Genoa a few months back, the material was Dacron and Tri-radial cut, I'm guessing a basic crosscut Main would be around $3000. My boat is a Carpenter 29 which is a little bigger than the Nova but I think roughly comparable in terms of fore Triangle area. If interested I still have the No 3 Jib/blade which has had little use and The no1 genoa (tri-radial Cruising Laminate) still in good nick both sails are hank on though. Quote Link to post Share on other sites
B00B00 361 Posted April 25, 2025 Share Posted April 25, 2025 I can't find many specs for the Nova 28 online or in my database right now but I would think I could supply both a main and genoa in Tri Dacron for around 5k. If you have any basic dimensions then I can price it up properly for you or if the boat is in Auckland I could come down and measure it up then quote. www.roguesails.co.nz 1 Quote Link to post Share on other sites
CarpeDiem 587 Posted April 25, 2025 Share Posted April 25, 2025 3 hours ago, B00B00 said: www.roguesails.co.nz Make sure you navigate to http://www.roguesails.co.nz unless you need an electrician and then https will be just fine Booboo makes great sails 1 Quote Link to post Share on other sites
