Bad Kitty 252 Posted June 21, 2011 Share Posted June 21, 2011 OK so our Cat 1 surveyor has sailed of into the sunset, lucky SOB, so any suggestions for a replacement. Tim C, are you out there? And do you do Cat 1? Link to post Share on other sites
tuffyluffy 76 Posted June 21, 2011 Share Posted June 21, 2011 Fossils your man. Link to post Share on other sites
Guest Posted June 21, 2011 Share Posted June 21, 2011 Fossils your man. Definitely. John brings a whole shedload of expertise and practicality to the process. If this your first time then I suggest getting him in in a private capacity to advise (at VERY reasonable rates, he'll make you buy his book). Listen to his advice and all will be good. Link to post Share on other sites
Infinity 1 Posted June 21, 2011 Share Posted June 21, 2011 Agree Fossil or Kevin Johnson Kevin Johnson Boat Builders Devonport Ph 445 0545 Link to post Share on other sites
Bad Kitty 252 Posted June 21, 2011 Author Share Posted June 21, 2011 Fossils your man. Definitely. John brings a whole shedload of expertise and practicality to the process. If this your first time then I suggest getting him in in a private capacity to advise (at VERY reasonable rates, he'll make you buy his book). Listen to his advice and all will be good. Thanks, not the first time, it's been away before but a new viewpoint is always valued, I'll track him down. Link to post Share on other sites
Steve Pope 243 Posted June 21, 2011 Share Posted June 21, 2011 Tim C is a cat1 inspector. Link to post Share on other sites
marinheiro 352 Posted June 23, 2011 Share Posted June 23, 2011 if you look over your right shoulder whilst standing in the cockpit of BK at the marina, you will see the option of "Fossil junior, aka Kevin, if you can ever prise him off the travel lift". Link to post Share on other sites
Guest Posted July 1, 2011 Share Posted July 1, 2011 Hi .Kevin Johnson do ours last year, reel help full Link to post Share on other sites
Bad Kitty 252 Posted July 1, 2011 Author Share Posted July 1, 2011 All sorted, thanks. Link to post Share on other sites
