Tiller 2 Posted July 28, 2012 Share Posted July 28, 2012 whats best sheeting angle for headsails.bout to put on genoa tracks at 11degrees ? someone suggested 7 degrees ? maybe go for sideways with barbers. Link to post Share on other sites
Absolution 7 Posted July 28, 2012 Share Posted July 28, 2012 Assuming your foils are nice go for 7degrees. Most "modern" race boats seem to end up about there. AC boats were more like 6 and 11+ would probably be more at home on a cruiser. Sideways tracks are nice if you're not going to carry an overlapper. Have you thought about ditching the jib tracks completely? Have seen a few boats just using inhaul and downhaul lines to a ferule to position the sheet. I'll see if I can find some pictures. Link to post Share on other sites
Absolution 7 Posted July 28, 2012 Share Posted July 28, 2012 Not the best photo but you'll get the idea: Link to post Share on other sites
all fired up 6 Posted July 28, 2012 Share Posted July 28, 2012 Did some work work with Norths on sheeting angles when getting new sails for my 930. The suggestion from their design computer was between 6deg and 7.5deg in light to moderate weather. We achieved this by using barber haulers to bring the sheeting angle in from the existing tracks on side decks. It worked too as our pointing improved a lot and our boat speed did not suffer. Using the existing tracks still gave us the option to widen the slot as the breeze freshened. a.f.u Link to post Share on other sites
Tiller 2 Posted July 28, 2012 Author Share Posted July 28, 2012 thanks fineline but probably to many strings to adust already have tracks off p.e. so will use them. will go with 7 degrees cheers Link to post Share on other sites
203 0 Posted July 28, 2012 Share Posted July 28, 2012 whats the new project? Link to post Share on other sites
Tiller 2 Posted July 28, 2012 Author Share Posted July 28, 2012 hope to be in water for last ssanz Link to post Share on other sites
TimW 1 Posted July 29, 2012 Share Posted July 29, 2012 The first real consideration before deciding on sheeting angles is what sort of leeway your boat is going to make. A narrow, vee'd boat like an Etchell with a decent (efficient) keel area is an ideal candidate for a narrow sheeting angle whereas a flat bottom barge will be much better off sheeted wide. Some planing style sporties or light keelboats may struggle at 7 degrees it really depends on the type of boat you have. Link to post Share on other sites
Battleship 100 Posted August 1, 2012 Share Posted August 1, 2012 Nice tidy setup on the new MC38, helps not having a coach roof though. Link to post Share on other sites
