Fire destroys brand new North Sea Boats 63m Stealth Fast Mis
You do have to laugh, a mega buck state of the art warship and then you see the fire fighting in the vid, looks like a couple of local who just happened along at the right time and found hose, which is too short :)
The thing was only a month old. Someones arse is in for a kicking.
That is burning just like Glass and Resin does. I suppose that is part of the stealth. Signals won't bounce off as easily as it would from a metal. But you would think there would be better firefighting systems installed due to a structure that can burn so easily. One tracer bullet and it's guyfawkes.
The new 63 metre long vessel is a cutting edge trimaran design that is considered to be the most advanced naval vessel of its type ever built in South East Asia. It incorporates a radical wave piercing hull form for improved seaworthiness and stability, and has been built from full carbon fibre composite materials, utilising the vacuum infusion process and vinylester resin. This method results in a structure that has increased strength, but also offers the benefits of lower operating, maintenance, and lifecycle costs.
In 2009 PT Lundin signed a contract to build a one of the most advanced “stealth” warships for TNI-AL (Indonesian Navy). This was the result of an intensive Research and Development programme conducted by PT Lundin Industry Invest (North Sea Boats) and TNI-AL that commenced in 2007. Construction commenced in early 2010, but due to the advanced design and construction methods, the project has been kept largely confidential until now.
The launching ceremony will be held on Friday 31st August, 2012 at PT Lundin’s shipyard facility in Banyuwangi, East Java. The ceremony will be attended by dignitaries and senior officers of TNI-AL, during which a briefing and Press Conference, and interviews will be conducted.
The Fast Missile Patrol Vessel (FMPV) employs a modern “Wave Piercing” trimaran design. This allows the vessel to cut-through waves rather than rise up and over them, and the increased beam provides inherent stability. This combination of features reduces both pitching and rolling, creating a stable weapons platform, and enabling the vessel to comfortably and safely maintain higher average speeds in adverse conditions.
The FMPV has “Stealth” design characteristics, and incorporate features that minimise detection by reducing Radar, Infra-Red, Acoustic and Magnetic signatures. Stealth properties are further improved as there are no reverse-angle bow overhangs to reflect radar signals, as seen on conventional hull forms. Weaponry, including missiles and naval guns, and the ships 11 m high-speed RHIB, are discreetly concealed or shaped to meld into the superstructure profile.
The wide decks on the 63m OPV Trimaran also make it an ideal platform for carrying a helicopter, which extends the effective patrol range and capabilities of the vessel.
If you can't find it you can't shot it !
Golly gosh? Is it invisible to binoculars too? :crazy:
Why find something that floats on top of the surface. Its the subs that are a worry.
Why have none of the billionaires not built super subs?... or....
You know that there is such a thing as FLIR these days, jet turbine powered waterjet zoomies have thermal bloom out the jacksie that makes a old wooden diesel PT boat look stealthy.
UAVs with FLIR and IR homing mavericks would soon have that ship sinking while old 70's tech radar search focused cruisers with radar homing AS missiles are still looking.
For every magic armour like stealth, there is a magic bullet being loaded into someones gun right then.
