Bogan 8 Posted February 3, 2013 Share Posted February 3, 2013 A few more things from the garage that need to go. Make me an offer: Keelboat hardware: 2xBarlow 23 winches - not self tailing, black alloy 25# Manson plow anchor - good condition 18# (I think) Danforth - (stock is 70cm long, blades are 45cm, cross bar is 40cm) - good condition. A few skiff bits: Some skiff sails: 2 Geni's, 2 mains - came to me with an old (90's) R-class some years ago. Rudder and centreplate - also from the old R-class, foam and carbon. Link to post Share on other sites
Guest Saturday Night Special Posted February 5, 2013 Share Posted February 5, 2013 Wher r u and Whats The skiff Hull ? and The gennakers got a pic of them What Do you want for these bits Link to post Share on other sites
Guest Saturday Night Special Posted February 5, 2013 Share Posted February 5, 2013 Where r u and Whats The skiff Hull ? and The gennakers got a pic of them What Do you want for these bits Link to post Share on other sites
Guest Posted February 5, 2013 Share Posted February 5, 2013 How big are the mains and centre board? Link to post Share on other sites
Bogan 8 Posted February 6, 2013 Author Share Posted February 6, 2013 Located at Pt Chevalier. The hull is in the local kindy, inspiring the next generation of pirates. R-class 561 I think (bigger genni is marked with this number). The larger genny is still crunchy, and seems OK. The smaller is well used, and probably suitable for the rubbish bin. On checking this, it appears I have discarded one main somewhere along the way. The remaining one is from Linton sails. Presumably measures for R-class. Looks basically unused - very high aspect ratio, perhaps an experiment that didn't work? You can pay whatever you think an item is worth - free even. It needs to get out of my garage and preferably have an extended life somewhere else. Link to post Share on other sites
203 0 Posted February 6, 2013 Share Posted February 6, 2013 got a picture of the rudder bogan? also some measurements ? Cheers! Link to post Share on other sites
Bogan 8 Posted February 10, 2013 Author Share Posted February 10, 2013 rudder is 900mm from lower gudgeon to tip. Chord varies, but is about 27cm at its widest. max Thickness is about 25mm board is 1.5m long, and chord is about 32cm at its widest point. max Thickness is about 55mm. Link to post Share on other sites
Bogan 8 Posted February 26, 2013 Author Share Posted February 26, 2013 A few more things from the garage that need to go. Make me an offer: Keelboat hardware: 2xBarlow 23 winches - not self tailing, black alloy 25# Manson plow anchor - good condition 18# (I think) Danforth - (stock is 70cm long, blades are 45cm, cross bar is 40cm) - good condition. A few skiff bits: Some skiff sails: 2 Geni's, 2 mains - came to me with an old (90's) R-class some years ago. Rudder and centreplate - also from the old R-class, foam and carbon. The gennys are gone. Everything else is still up for offers. I also have: a prod and spreader arrangement off the skiff two different dinghy goosenecks (one for track and one dick type) a fuel tank level sensor (float type, no gauge) a wind sensor (was from a Navman 3100 system, but I think works with other head units?) - good working condition, but no mast mounting - so a replacement for someone who has broken one. a couple of old cleveco winch handles a long pair of oars (2.5m long) in very good condition. stainless steel vang ram (needs new spring, and escludes mast fitting). Choose your price. Everything must go somewhere. Link to post Share on other sites
203 0 Posted February 26, 2013 Share Posted February 26, 2013 any photos of the prod? Link to post Share on other sites
Deep Purple 511 Posted February 26, 2013 Share Posted February 26, 2013 Dibs on the Navman wind sensor please, I'll check my unit Link to post Share on other sites
Bogan 8 Posted February 26, 2013 Author Share Posted February 26, 2013 Photos of the various bits of gear: Link to post Share on other sites
