Ptown 14 Posted April 1, 2013 Share Posted April 1, 2013 I've got brass(?) rudder gudgeons and pintels (which might be stainless if I looked again), and some serious slop in the steering which drives me mad. I have plastic bushes made about 18months ago which have worn out. What's the fix? I would say plastic is not the way to go again. Is brass too soft? do people have both fittings in stainless? Is this more durable? Alternatively, who supplies these types of fittings if new is the best option? Link to post Share on other sites
Steve Pope 243 Posted April 1, 2013 Share Posted April 1, 2013 Oil impregnated plastic or bronze bushes should be the go, Not brass and definitely not SS, SS can gall and then you would not be able to steer at all. Link to post Share on other sites
dkd 3 Posted April 1, 2013 Share Posted April 1, 2013 Nolathane (if you want "plastic") or Bronze, or preferable is gunmetal .... but clearances need to be sufficient so they don't bind. Brass will give you plenty of clearance as it happily corrodes in saltwater Link to post Share on other sites
Guest Posted April 1, 2013 Share Posted April 1, 2013 I have, or had until Saturday, stainless on stainless. Freaking heavy but then so is the bucket full of all the deck gear nut/bolt fixings. I think I could fund a new kite from the scrap value. Anyway no drama with SS on SS. More slop in the liteweight tiller than the gudgeon's. When you find the fix tell Mr Squid V, he's a sloppy bugger................... as is his boat Link to post Share on other sites
Bill 0 Posted April 1, 2013 Share Posted April 1, 2013 My boat has SS gudgeons and pintels with oil-impregnated flanged bronze bushings that are about $7 a pair. Replacing the bushings is part of my annual maintenance, like replacing prop zincs. They’re a slip fit into the gudgeons, so changing them is no big deal. I suspect the oil impregnation keeps them from galling. They make the rudder really snug when new and loosen up slowly over the year. Link to post Share on other sites
Ptown 14 Posted April 2, 2013 Author Share Posted April 2, 2013 OK, so must be bronze not brass...(slaps forehead) Those bronze bushings sound like the ticket, where do I get me some? Link to post Share on other sites
Bill 0 Posted April 2, 2013 Share Posted April 2, 2013 Can't answer the where locally -- I'm not far from Seattle -- but Googling "Bearings New Zealand" shows several possibilities. Bushings are just bearings. You'll need to measure OD, ID and length or take the old bushings in with you. I'd bet they're a pretty common item. Link to post Share on other sites
Guest Posted April 2, 2013 Share Posted April 2, 2013 Try Auckland Bearing Distributors in Wairau Valley or Manukau. I know they have boaters working there, in Wairau at least, so should be able to help. They have a massive range of stuff. Link to post Share on other sites
