Clive 13 Posted June 2, 2017 Share Posted June 2, 2017 Anyone know where I can get some material for making a fender? Quote Link to post Share on other sites
ex TL systems 63 Posted June 2, 2017 Share Posted June 2, 2017 i used 70mm red fire hose to make a fender for my dinghy , folded the ends and put a car valve in and inflated to about 3 psi , no leaks and a 5m long fender Quote Link to post Share on other sites
Kevin McCready 83 Posted June 2, 2017 Share Posted June 2, 2017 i used 70mm red fire hose to make a fender for my dinghy , folded the ends and put a car valve in and inflated to about 3 psi , no leaks and a 5m long fender How did you attach it to the gunnels? I used plastic hose from Bunnings and used SS screws into aluminium gunnels - has last more than a year so far. Quote Link to post Share on other sites
wheels 544 Posted June 2, 2017 Share Posted June 2, 2017 KM at Chains Ropes and Anchors has the dockside fender in lengths of about 4 or 5 m and it isn't that expensive. Quote Link to post Share on other sites
Clive 13 Posted June 2, 2017 Author Share Posted June 2, 2017 i used 70mm red fire hose to make a fender for my dinghy , folded the ends and put a car valve in and inflated to about 3 psi , no leaks and a 5m long fender That's a good idea. Forgot to add .. I want to make an inflatable fender. Quote Link to post Share on other sites
wheels 544 Posted June 2, 2017 Share Posted June 2, 2017 KM also sells fenders. OK, those things a tad more pricey, but not hugely so and I really don't know how you would make one quite as strong any cheaper. I have seen them made from heavy reinforced PVC fabric, but you need to be able to seal the seams. The best way to do that is heat seal fusing them together, but you need special equipment to do so. Quote Link to post Share on other sites
ex TL systems 63 Posted June 2, 2017 Share Posted June 2, 2017 How did you attach it to the gunnels? I used plastic hose from Bunnings and used SS screws into aluminium gunnels - has last more than a year so far. I just lashed it every 600mm or so drilled small holes in the gunnel and used thin cord, adds a lot of bouyancy if the dinghy should get swamped too. Hose was free , valve was free so total cost was not much at all. sealed it by simply folding and clamping the ends with ally and 2 bolts. Quote Link to post Share on other sites
Clive 13 Posted June 2, 2017 Author Share Posted June 2, 2017 Sorry, I should have been a more specific, I want to make an inflatable fender to go around a Zephyr so I don't bash it. Kinda like the tubes on an inflatable dinghy. I can sail into it and from it - bit like a dock. Quote Link to post Share on other sites
mattm 106 Posted June 2, 2017 Share Posted June 2, 2017 Buy / Aquire an old inflatable dinghy with the floor ripped out. Remove the transom and floor completely and your done? I'm assuming you mean so you can take the zephyr as a dinghy behind a keeler, but don't want the zephyr to bump the keeler when it's not being sailed? Quote Link to post Share on other sites
Clive 13 Posted June 3, 2017 Author Share Posted June 3, 2017 Buy / Aquire an old inflatable dinghy with the floor ripped out. Remove the transom and floor completely and your done? Good idea. Quote Link to post Share on other sites
