Jigsaw blades?
On 17/05/2020 at 12:35 PM, lateral said:
As per eruptn, or the tungsten carbide insert ones but bigger teeth than TCIM for thicker laminate.
Got mine from Gail at Alltrades.
Doesn't clog like the coated particle ones but go slow.
Did all my window openings with them.
 We used the particle ones for cutting out fins from a 12mm solid laid up panel.
Do you have any pictures of the blade you acquired and how long did each one last?  I am cutting 12mm - 15mm solid polyester based fibreglass.
43 minutes ago, lateral said:
I’ll check if I have any left tomorrow. From memory they lasted longest of any blade but weren’t suitable for tight radii.
Used high tooth count TC skilsaw for the straight runs. Thicker kerf.
The particle ones we used were TC as well. Diamond weren’t  available then.
How tight of a radius could you do?   I need to cut two 190 mm round holes.
