vic008 17 Posted December 16, 2020 Share Posted December 16, 2020 'Liquid Piston' inside out rotary X engine.Sounds very good. Quote Link to post Share on other sites
SloopJohnB 323 Posted December 16, 2020 Share Posted December 16, 2020 If you spin the rotors fast enough they form a semi liquified solid is that the same?🤔 Quote Link to post Share on other sites
kiwi_jon 26 Posted December 16, 2020 Share Posted December 16, 2020 23 minutes ago, SloopJohnB said: If you spin the rotors fast enough they form a semi liquified solid is that the same?🤔 LiquidPiston is the name of the company producing the Rotary X mini engine. http://liquidpiston.com Quote Link to post Share on other sites
aardvarkash10 959 Posted December 16, 2020 Share Posted December 16, 2020 still has the inherent problems of the Wankel engine - thermally inefficient (huge surface areas that are exposed to the combustion process and draw heat that should be converted to motion); dynamically challenged seals that require total loss lubrication with the inherent emissions issues that this has etc. Overall I don't see any significant advances over, say, forced induction wankel - a point they make themselves in passing. Its clever, but not world-changing. Further, its too late. It required fossil fuels. This is a narrow niche market product at best. Quote Link to post Share on other sites
