Thanks Gents!   That is very helpful.  Looks like I got pretty close.  I can definitely grab more wind and carry it down with good boat speed.
What does your luff look like?   I'm debating whether I need to rig a 4:1 tack to increase luff tension, but I'm not sure what an optimal luff would be for a sail like this.
The luff line is 6mm Dyneema and thus should be able to take a load.  However, if I head up a bit high, and luff the luff, it responds with a loud CRACK! when I fall off.   I would like to minimize this because of the shock on the very light fabric.   It is two layers of .75 Mylar with a grid of Twaron fibers in between.
As info, the prod is 2 meters long.
Share this post
The loud crack is something i experienced with my old screecher. I always thought it was lack of luff tension that caused it.  I have a normal 1:1 halyard, which I haul to the top. then i use a 2:1 tackline onto a winch. we winch until too scared to winch any more. I believe you should have as much tension as you can on the luff.
Share this post
baring in mind
has more than enough strength to lift your entire boat out of the water which is also more the more than enough to rip your rig out of the boat.
Share this post
