Sign in to follow this
Kiwi led world speed record
...knot that I should be encouraging a Kiwi record....
but foilers seem to be the logical next step. Reducing the water drag.....sails are gone...solid wing sections.
I need to find out more, but I have been told that there is a 26 foot tri that is a foiler. It (i have been told) will do 26 knots in 10 knots...
Share this post
Hmmm, Foils are hardly a next step. They have been around for as many years as solid wings for sails or maybe even longer. The trick now is to get daimensions down to a fine edge of balance between making it powerful enough and yet maintain the least friction. And that is for both Sail and Foil. That is why they can go from Speed machine to Train wreck in an instance.
Share this post
forget the sailing - I'll go with the Green Command pod of girls !
Well, there are my ideas anyway. I think I need to find somebody who is some sort of a design specialist, who understands the forces involved - and Really understands how to determine C of E for etc, for sort of craft, and can 'model' it using software.
Can anybody recommend such a person pse ??
Meanwhile, take a look at these pics .. and tell me this sort of stuff isnt exciting :D
Share this post
To model C of E, you first have to have data to input. Sure you can have a good educated guess if you are an experienced enough designer. But it will never be accurate enough to make the fine detailed calculations playing with the toys in the Pictures. So you need to build a model and then test and then scale up. That's why they spend so much time in wind tunnels. Then once you have the data, you can start changing things on a computer model and see the differences. The more data you can input, the greater the accuracy in the output.
Share this post
Right .. Agreed - that a mix of skills is required - and they dont have to (or rather, is unlikely to) reside in one person. So far then, for Design phase we need:
- Aeronautical / marine engineering design skills
- Software modelling skills - for something like 'Solidworks' ..
What other skills are required, in a team to design a potential, world beating craft ??
Assumptions (for now): Wish to:
1) Use proven configuration (e.g Longshot), as basis for design
2) Use 2 x Windsurfer sails (like Longshot) because of cost factors
3) Use foils - like http://carafinohydrofoilboard.com/development
4) Consider use of modern 'glider pod', as basis for crafts aerodynamic pilot pod, craft controls, and craft attachment points for craft outriggers (rather than wings).
OK Can anybody recommend such a person / persons, or design consultancy, which might have the right 'smarts', skills, and pragmatic mindset ??
Cheers DHRB
Share this post
Wellllllll, there's a problem right there. Two problems actualy. The words "cost factor" is problem no.1. You can't have a limit to "cost factor" when designing these kind of things. No2 is you can't start the entire design with limiting the most essential part of the design right from the get go. Think of it this way, the Dream Liner didn't get designed because someone said, we have this wing sitting out the back of the workshop that should do, it's worked OK on the 747 aircraft we biult, so lets start with that and work backwards. You just end up with a slightly different version of the 747. You have to start with want you want to achieve. That would be "speed". Then what on. That would be Water or Sand. One requires wheels and the other requires a Hull. Both have different ways of providing the Friction, so you have to engineer then means of least frisction with greatest speed. And that is where all the designs come unglued. At some point, the design will reach a speed where the speed equals the coefficient of Friction and the craft wants top change from a ground based design to an air based design. Lots of other design issues and restraints fill the gaps between that and the end result which is the wing to power it all. So in reality, unless you can do a lot of it yourself, you need to have boatloads of cash and the means of digging up even more boatloads when needed. So often the guys behind such projects are very good at finding thiose Boatloads. Hence a great deal of time Grant Dalton spends is in finding money for Team NZ.
Share this post
Point taken .. Thanks man .. forces us to think critically ..
Cost is a contributing reason. However, the main reason for planning on using windsurfer sails is based on the observation that the (outright) record has swung back and forth between Massive craft / budget (i.e. Yellow Pages and Hydroptere) - and windsurfers. The point being that a well designed, highly efficient simple craft can match a huge budget, big craft. So I have chosen to go the 'simple and efficient' route ..
The other reason is back to this principle of developing an already good / proven idea. This makes sense to me. Longshot still has the 'Class A record' which it set in 1992. And of course it used old fashioned windsurfer sails. I reckon the Longshot type configuration is a good one - so reckon it makes sense to use it - and make it better ..
See, I am putting it out there on the forum, cos I want to be instrumental in generating some excitement round this - and gathering a team of like-minded people, with the right skills and abilities to actually 'do something' .. so there you are: wearing my heart on my sleeve ..
So folks: do you have any professional skills / expertise which you would be (potentially) willing to bring to the table ? You can always email me. dhrbernard@gmail.com or ring me on 027 6660904
Cheers DHRB
Share this post
The problem with a windsurfer Sail is, think about how a windsurfer works. The surfer is connecting the driving Force from the sail to the board. He is holding the sail at the Mid point ruffly, so the cut is such that the sails power is developed at around that balance point. If to much energy was developed high up, the Surfer would be pulled over. Too far back, and the Surfer would struggle to pull the sail toward him. Too low down and the board would be pushed sideways too much. The design suits the purpose. A Windsurfing sail would prbably not work well on a Sailing Dingy for instance. So for the speed machine, you have to design the sail as part of the package. Where do you want the CoE and so on. It is all quite complex. I understand enough of the process to understand that I don't know enough about being a good yacht designer.
Share this post
I think though the suggestion is solid foil sails but using the configuration of Longshot which happened to use windsurfer sails. So a bi-plane rigged foil/sail (aka AC45's for want of a better phrase) on foils. Clearly the concept will work and just replacing the old windsurfer sails with foils should result in an improved performance.
I've got no skills to offer you other than encouragement and best wishes. Trifoilers are awesome and I love the concept!
Share this post
