gonzo 0 Posted April 29, 2014 Share Posted April 29, 2014 Ok so on my first long dark evening with this Open CPN I have got to the point where I'm loading the NZ LINZ charts into the program. The LINZ download produced 181 folders of NZ charts. Is there a way of loading all of these at once or do I need to load them folder by folder as it seems to this point? I got to about the 4th folder and realized just how many were there - hence this post! Link to post Share on other sites
grant 40 Posted April 29, 2014 Share Posted April 29, 2014 Ok so on my first long dark evening with this Open CPN I have got to the point where I'm loading the NZ LINZ charts into the program. The LINZ download produced 181 folders of NZ charts. Is there a way of loading all of these at once or do I need to load them folder by folder as it seems to this point? I got to about the 4th folder and realized just how many were there - hence this post! When I did that all the NZ charts were in one folder and I just copied that, got it from here http://www.linz.govt.nz/hydro/charts/digital-charts/nzmariner Link to post Share on other sites
Guest Posted April 29, 2014 Share Posted April 29, 2014 My eeepc uses about 0.4 or 0.5 amps. Link to post Share on other sites
ex TL systems 63 Posted April 30, 2014 Share Posted April 30, 2014 i have a netbook with open cpn loaded ,and can power it from a inverter on the boat. I also have 2 handheld garmin gps but no connection to the netbook. I thought it would be easier to buy a usb gps aerial to get the netbook running as a plotter etc.? Link to post Share on other sites
Island Time 1,239 Posted April 30, 2014 Share Posted April 30, 2014 Powering it from an inverter is really inefficient! Way better to use a DC to DC power supply. You can buy a USB GPS, or you can use a usb- serial adapter if you have a GPS that outputs nmea. See the front page for connection info. The hockey puck GPS units are ok, but a proper marine GPS with antenna is better. ☺ Link to post Share on other sites
