chic014 0 Posted August 17, 2014 Share Posted August 17, 2014 My new windows which I put on a few months ago have popped off on one side only. Used sika primer with the proper black sika window sealant with thick matchstick spacers. About 3mm. All according to the spec sheet. It appears to have let go between the primer and the acrylic. I didn't surface prep the acrylic, just peeled the paper off and brushed on the primer. The side that has popped off is north facing but I'd hoped using the matchstick spacers would've made the differential thermal expansion a non issue. Maybe there was some contaminant on the acrylic before the primer? Any ideas? Link to post Share on other sites
sow1ld 2 Posted August 17, 2014 Share Posted August 17, 2014 I always give the acrylic a prep up. Was it cold the day you put them in? Link to post Share on other sites
chic014 0 Posted August 17, 2014 Author Share Posted August 17, 2014 No not a cold day. Was late summer when they went in Link to post Share on other sites
Dambo 44 Posted August 17, 2014 Share Posted August 17, 2014 You need to prep the acrylic. Link to post Share on other sites
Chewing Gum 17 Posted August 17, 2014 Share Posted August 17, 2014 We use sikaflex ms on glass windows and it works well Link to post Share on other sites
