Bit of a southerly in Wellington, 1st for a while
Island Time
Nope, don't agree. When i was in a 80 knot storm, when it got down to 50 it seemed quite reasonable! WInd force is a logarithmic scale - the force is multiplied way more than the wind speed increments... the numbers mean a lot, and progressivly more not less.
Yep and temperature has a bigger impact than many realise as well. The colder the air, the more dense it is and we all know about Mass x Velocity.
The Ferries did not sail yesterday and the Bluebridge left this morning at 7AM and it took 7hrs to sail across. Yet as per usual, it is Sunny and calm here in Blenheim. Had our first frost of the year.
Absolutely - can hold full sail in the tropics longer than you can down south - but also, wind speed gear accuracy alters with temp/density as well...
Yep, common DS, but it depends - the really advanced windgear, like the top end B&G stuff, remove mast movement errors (using mast length data and pitch/roll/yaw sensors) and are surprisingly stable and accurate. Even the next level down (Triton) has averaging to try to reduce the error. So the answer to that is, like lots of things, it depends....
Temperature also has a big influence on how big waves become as well. For intance, 40kts in the Tropics does not produce anywhere near as big a sea state as 40kts of Cold Southerly down South does. 40kts of Hot norwester on the East Coast will create some white caps and not much wave height, but get 30kts of cold Southerly and there will be a good wave height with it.
