Beccara 25 Posted September 4, 2017 Share Posted September 4, 2017 Has anyone come across any West's Six10 for sale in NZ? I've got a few small jobs to do and breaking out the 105 and pumps is messy and wasteful, Six10 and the "resin/hardener packets" would make small jobs much easier for me. I was hoping to avoid mixing systems on the boat but if I have to I have to, If anyone knows of similar products let me know Cheers Quote Link to post Share on other sites
MartinRF 53 Posted September 4, 2017 Share Posted September 4, 2017 I use small, cheap, plastic soap dispensers for my easy to bring epoxy repair kit. The local (Swedish) epoxy brand I use have a 2:1 volume ratio so 2 pushes on the resin pump for every time I push down the hardener pump. The result is a tablespoon's worth of epoxy. /Martin 1 Quote Link to post Share on other sites
Black Panther 1,601 Posted September 4, 2017 Share Posted September 4, 2017 Love it - thank you. Quote Link to post Share on other sites
Beccara 25 Posted September 4, 2017 Author Share Posted September 4, 2017 *doh* Why didn't I think of that Quote Link to post Share on other sites
Guest 000 Posted September 4, 2017 Share Posted September 4, 2017 Otherwise, a couple of graduated plastic syringes are perfect for accurately drawing up small quantities of resin and hardener. The best sort are catheter syringes which are 60ml capacity and have a long tapered spout on the end. Normally used for squirting warm water up your Willie but ideal for drawing up resin. Get a few from St.John or your GP. Quote Link to post Share on other sites
Fish 0 Posted September 4, 2017 Share Posted September 4, 2017 I've used a set of digital kitchen scales (just like the drug dealer ones, but for baking cake) and some disposable plastic cups. Just measure by weight the amount I need. Works well in the 20 g to 40 g range for little jobs. Saves priming the soap dispensers. Quote Link to post Share on other sites
Beccara 25 Posted September 5, 2017 Author Share Posted September 5, 2017 I thought the metering pumps where volume based so had discounted a "by weight" option but handy ideas Cheers Quote Link to post Share on other sites
Vorpal Blade 89 Posted September 5, 2017 Share Posted September 5, 2017 $2 shops have all manner of small cheap as throw away mixing containers. KFC spoons make great coving tools....but you do need to eat a lot of spud n gravy or coldslaw if you are doing a big job . Hey KM, Ive found a great small diameter coving tool is knob end part on a motorbike brake lever, the spherical shape lets you cove around a right angle corner in one clean swoop. Cheap as from the wreckers in Barry Pt rd. Quote Link to post Share on other sites
Black Panther 1,601 Posted September 5, 2017 Share Posted September 5, 2017 I used round coasters from the local pub and treated them as disposable. Quote Link to post Share on other sites
chic014 0 Posted September 5, 2017 Share Posted September 5, 2017 Just be careful, by weight and volume the ratios are a bit different because of different densities. Gurit spabond 345 is a good pre thickened adhesive for bonding, not really for coving though. Quote Link to post Share on other sites
