Chewing Gum 17 Posted May 15, 2018 Share Posted May 15, 2018 I have a ICOM VHF Handheld IC-M33 which is not receiving. It appears to be working ok part from that ie it is transmitting ok. Any ideas ? Quote Link to post Share on other sites
Island Time 1,241 Posted May 15, 2018 Share Posted May 15, 2018 Broken antenna?? Ive seen internal issues with the antennas, if you flex it, does it feel consistent resistance along its length? Quote Link to post Share on other sites
Chewing Gum 17 Posted May 15, 2018 Author Share Posted May 15, 2018 Wondered about that - it is slightly bent. Guess the thing to do would be to find someone with a similar radio. ICOM want $115 just to look at it. May as well buy a new one. Any recommendations for radios ? Quote Link to post Share on other sites
kiwi_jon 26 Posted May 15, 2018 Share Posted May 15, 2018 Squelch level set to high? Speaker stuffed? Try using the AquaQuake function. You should hear a vibrating beep from the speaker. Quote Link to post Share on other sites
Island Time 1,241 Posted May 15, 2018 Share Posted May 15, 2018 Simrad HH36 (or Lowrance Link2), with DSC $350.00, Built in GPS, floats in seawater, large clear screen, totally waterproof to JIS 7. 5w/1w or low cost options; Burnsco; GME GX625 Handheld VHF, 1/5 w, Ip66 https://www.burnsco.co.nz/searchresults.aspx?q=handheld%20vhf You get what you pay for, except ICOM's are expensive... Quote Link to post Share on other sites
Chewing Gum 17 Posted May 15, 2018 Author Share Posted May 15, 2018 Thanks IT Speaker fine - sound comes from speaker with squelch open and Aquaquake sound works fine. The radio is 10 years old from Safety at Sea and I bought it because of ICOM's reputation but the the thing has hardly been used and is in mint condition, with no salt damage so not too happy with ICOM any more. Quote Link to post Share on other sites
Island Time 1,241 Posted May 15, 2018 Share Posted May 15, 2018 Oh, should have said, the Simrad Lowrance price is from me, special for crew.org members... Quote Link to post Share on other sites
Dagwood 57 Posted May 15, 2018 Share Posted May 15, 2018 Simrad HH36 (or Lowrance Link2), with DSC $350.00, Built in GPS, floats in seawater, large clear screen, totally waterproof to JIS 7. 5w/1w Great features there. Have they got any smarts to seal with MMSI numbers if you're using it on different vessels? Quote Link to post Share on other sites
erice 732 Posted May 15, 2018 Share Posted May 15, 2018 the drawings show a removeable antenna remove it, connect a meter? of wire to the centre connector on the radio tune to the weather channel Quote Link to post Share on other sites
Island Time 1,241 Posted May 15, 2018 Share Posted May 15, 2018 Great features there. Have they got any smarts to seal with MMSI numbers if you're using it on different vessels? No, sorry. Ive not seen one that does that. Without MMSI the DSC function does not work. NZ is behind the times here, in europe and US this is a standard feature. Changing the MMSI requires a visit to a dealer. Basic features here; Quote Link to post Share on other sites
