Winter 42 Posted December 30, 2021 Share Posted December 30, 2021 Can someone help me with a software update for TP32. I have a second hand, new to me TP32. Just installed on my boat. NEMA2000 hooked up with the network and its showing in the devices list on my Zeus3 MFD. I've found a software update file (.swup) on the simrad website, and FTP it to the Zeus, but the TP32 doesn't show in the list of compatible devices when I try to upgrade (Files -> TP10-22-32 1_1_04_00.swup -> upgrade) Any ideas? @Island Time Quote Link to post Share on other sites
Island Time 1,347 Posted December 31, 2021 Share Posted December 31, 2021 Probably too many versions in between. Call navico on 08004628426 and they should be able to help. I'm away, and in poor reception area, back 21 Jan... Quote Link to post Share on other sites
Winter 42 Posted December 30, 2022 Author Share Posted December 30, 2022 Anyone familiar with the SWUP tool know what the status 'maintainence mode' sad faces and ! are about? I'm trying to update this TP32 and its failing. Navico support no help at this time of year Quote Link to post Share on other sites
Winter 42 Posted December 30, 2022 Author Share Posted December 30, 2022 Futher, the current version showing on my TP32 is 0130, which not even in the same format as the latest 1.1.04.00 version Quote Link to post Share on other sites
Winter 42 Posted December 30, 2022 Author Share Posted December 30, 2022 Quote Link to post Share on other sites
Psyche 913 Posted December 30, 2022 Share Posted December 30, 2022 Pretty sure that there was a hardware update in the early teens that makes the old versions non compatible with updates. Quote Link to post Share on other sites
Winter 42 Posted December 30, 2022 Author Share Posted December 30, 2022 feck, I was worried someone would say that. Maybe navico has a list of serial numbers? Anyone want to buy a tp32 thats not compatible with newer nmea2000 stuff? Quote Link to post Share on other sites
Psyche 913 Posted December 30, 2022 Share Posted December 30, 2022 It should still work with 2000, Ive had both early and late models and the only difference in the updates is a not very noticeable refinement of its performance. Quote Link to post Share on other sites
Winter 42 Posted December 31, 2022 Author Share Posted December 31, 2022 2 hours ago, Psyche said: It should still work with 2000, Ive had both early and late models and the only difference in the updates is a not very noticeable refinement of its performance. Mine cant be controlled from the MFD, and behaves different to the manual says it should, for example when tacking, manual says it will beep three times as warning then tack, whereas mine just goes straight away. Im not convinced it steers to wind either. Quote Link to post Share on other sites
Island Time 1,347 Posted December 31, 2022 Share Posted December 31, 2022 I can probably sort it for you when I'm back. I'm at westhaven tomorrow for a warranty job if your nearby? Planning to go boating Monday until 13th... Matt Quote Link to post Share on other sites
Winter 42 Posted December 31, 2022 Author Share Posted December 31, 2022 Hoping to be back in Westhaven by midday, that could work out? would be great Quote Link to post Share on other sites
Island Time 1,347 Posted December 31, 2022 Share Posted December 31, 2022 Ill be down by A pier. You'll see the Neptune's Gear Van, give me a call when you get there and I'll come up. Only issue will be that I intend to go out in the boat until 13th on Monday, and probably wont be able to do it until I get back. If you want it meantime, probably best to hang onto it for a bit, and I can do it when I really return to work? Matt 0221539176 Quote Link to post Share on other sites
Screwball 9 Posted January 12, 2023 Share Posted January 12, 2023 @WinterI'd be interested to see how you got on with this? I had a similar issue with trying to update an old TP22 (also running 0130) through the MFD. Simrad support reckoned it should still be updateable through the ST10 gateway but not the MFD. Quote Link to post Share on other sites
Winter 42 Posted February 3, 2023 Author Share Posted February 3, 2023 hey @Screwball - Sadly, I got nowhere. Navico support were no help, disappointing, as if they didn't even read what I had written and just copy pasted the how to update section from the manual. I need to try them again on the phone, but they are only open business hours and I'm not at the boat business hours... Quote Link to post Share on other sites
Winter 42 Posted February 3, 2023 Author Share Posted February 3, 2023 @Screwball if you are in auckland and want to try with my ST10.. you are most welcome. Quote Link to post Share on other sites
Screwball 9 Posted February 4, 2023 Share Posted February 4, 2023 Thanks @Winter, I'd be keen to take you up on that. Just need to dig out my simnet to micro c cable then I'll drop you a DM. Cheers Quote Link to post Share on other sites
Winter 42 Posted February 4, 2023 Author Share Posted February 4, 2023 dont bother, I have one with the ST10. Bonus pic from the anchorage tonight Quote Link to post Share on other sites
