DrWatson 381 Posted December 3, 2010 Share Posted December 3, 2010 Wasn't sure where to post this but. What are the limits to the work you can do on your boat on the grid, or dried out on the mudflats? Obviously scraping off the old anti-foul is a no no, but are you allowed to for example: Take your old prop off and install a new one? Change your anode? Clear the growth out of your cooling inlet pipe? Cut the barnacles off the bottom of your keel? Apply anti-foul as long as you don't need to scrape the old stuff off? To what extent can you clean your boat in the water? Just a gentle scrub (which liberates anti-foul anyway) or can you cut the forest off the waterline and harvest the mussels? Just wondering what's allowed and what's not. Link to post Share on other sites
wheels 543 Posted December 3, 2010 Share Posted December 3, 2010 Yeah pretty much as you just described. It's only the large amount of AF being cleaned off in one place they don't like. Nor should they. However, I reckon if you captured it by placing ground sheets under the boat, there shouldn't be a problem. But it is a case of trying to convince the powers to be about that. I reckon heavy material sheets like painting drop sheets so as water will run through it, but all paint captivated would work well. Link to post Share on other sites
Murky 1 Posted December 3, 2010 Share Posted December 3, 2010 I guess it comes down to what's practical/cost-effective as well, especially in Auckland where you have the Floating Dock and numerous competitively-priced travel-lifts. If it's just a small job that can be done well in-between tides (changing prop/anode etc) the grid approach makes sense. However, if you're going to be applying a couple of hundred dollars worth of antifoul, to me it is more logical to come right out and do the best possible job to get value out of what you are ideally hoping will last a couple of years. Link to post Share on other sites
wheels 543 Posted December 3, 2010 Share Posted December 3, 2010 That floating Dock dock would be the go I reckon. Not too expensive. But as for these guys with the travel lifts, they are just rediculously expensive from what I have seen so far. Link to post Share on other sites
John B 106 Posted December 3, 2010 Share Posted December 3, 2010 The last time I put a boat on the grid at westhaven I had to provide proof of insurance and sign a document which guaranteed that the boat had been cleaned within 6 months . There were all sorts of other conditions. No paint to be applied at all , light clean only such as you would do to remove a light slime. There was no problem with changing props or anodes but if they saw you chopping weed and barnacles , I think there would be. Link to post Share on other sites
ex Elly 203 Posted December 6, 2010 Share Posted December 6, 2010 Right so if your boat if heavily fouled just employ a diver and do it on your marina berth. But if your boat is lightly fouled do it on the grid. Makes a lot of sense Link to post Share on other sites
