Black Panther 1,586 Posted February 4, 2023 Share Posted February 4, 2023 Has anyone used it? With all the recent damp the decks and canvaswork both growing things. Would it work? Is runoff likely to damage my awlgripped hull? Quote Link to post Share on other sites
Priscilla II 392 Posted February 4, 2023 Share Posted February 4, 2023 47 minutes ago, Black Panther said: Has anyone used it? With all the recent damp the decks and canvaswork both growing things. Would it work? Is runoff likely to damage my awlgripped hull? I have used Move It for many moons without any issues. Dilute apply leave safe and effective. From memory the active ingredient is the same for most of these type of products non caustic no bleach. Quote Link to post Share on other sites
Steve Pope 243 Posted February 4, 2023 Share Posted February 4, 2023 Wet n forget, good stuff, As I wrote in an earlier post Wheels did a thing on it and recommended it. I have it onboard, wouldn't use anything else Quote Link to post Share on other sites
vb1 0 Posted February 6, 2023 Share Posted February 6, 2023 One word -sodium hypochlorite. Doesn't matter what brand if that is the active ingredient. Which ever you chose you need to wet or spray the surface and then either forget for a pre-specified period as stated on the label or just walk away. Quote Link to post Share on other sites
mcp 32 Posted February 6, 2023 Share Posted February 6, 2023 On 4/02/2023 at 8:10 PM, Black Panther said: Has anyone used it? With all the recent damp the decks and canvaswork both growing things. Would it work? Is runoff likely to damage my awlgripped hull? Active ingredient in wet and forget is benzalkonium chloride, also found in the cheapest disinfectant in pak n save at a similar concentration minus the surfactants. 1 Quote Link to post Share on other sites
