alibaba 84 Posted May 31, 2023 Share Posted May 31, 2023 I'm starting to feel a bit think with this. After 25years, my starter is sounding that it needs a birthday, so I thought I would remove it and get it serviced - new brushes/contacts etc. However, on inspection, from both front and rear, I can only see access to one bolt. The motor is a Yanmar 3GMF. I've got a manual, which actually in not very helpful. Any advice please? Quote Link to post Share on other sites
ballystick 79 Posted May 31, 2023 Share Posted May 31, 2023 Not sure about your access in the boat but it looks to be mounted with 2 bolts, top and bottom. This video shows them https://www.youtube.com/watch?v=l2KTsGdomQw Quote Link to post Share on other sites
twisty 176 Posted May 31, 2023 Share Posted May 31, 2023 You might also find it cheaper to replace it. There is a shop on trademe that sells chinese copies.Last one I bought was $299. I'm sure they aren't as good as the original (over $1000). I've had one for several years with no problems Quote Link to post Share on other sites
harrytom 698 Posted May 31, 2023 Share Posted May 31, 2023 1 bolt is easy to get too,the other is hidden underneath,got to be a contortionist as I found out. 1 Quote Link to post Share on other sites
alibaba 84 Posted May 31, 2023 Author Share Posted May 31, 2023 Thanks Ballystick I too have researched and watched that video. The outside/right hand bolt is easily visible and accessible. BUT... if you look at the video, at no stage is there a look at the left hand bolt. It appears to be hidden between the starter flange and the inward curve of the engine crankcase. Even with removal of the air cleaner and alternator, I cannot even see it, let alone get a socket on it. I know I must be missing something here. The guy in the video also has effectively got full access to the side of the engine, whereas I, like most of us I suspect, have access to the front and the rear only. Quote Link to post Share on other sites
