foils
Après les ailes, les échasses ! En ce lundi matin, depuis 00h01, vous êtes les premiers à découvrir l'idée folle du defender américain de la Coupe : mettre des foils sous les flotteurs de ses AC45 ! Résultat : des vitesses totalement démentes, comme le prouve la flexion du foil sous le vent – pourtant en carbone. Les foils-dérives, qui ont été avancés, sont en «L» rentrant, les safrans, en «T» inversés. Mais, délicats à maîtriser, ces appendices seront-ils posés sous le futur AC72 ? / H.H.
After the wings, the stilts! On Monday morning, from 0:01, you're the first to discover the crazy idea of defending American Cup: put the foils in the floats of its AC45! Result: totally insane speeds, as evidenced by the bending of the leeward foil - yet carbon. The drift-foils, which have been advanced, are "L" returning, rudder, "T" inverted. But, difficult to master, these appendices will they be placed under the AC72 future? / H.H.
http://www.voilesetvoiliers.com/popup/3 ... des-foils/
Photos © Guilain Grenier / Oracle Team USA
i'm not convinced that is fully foiling as it appears. maybe launching off a wave, with the assitance of the foils?
The foils look kinda small?
I hope its real though, the potential for massive crashes is the even higher!
Photoshop?
IM not the biggest fan of the foiling L boards for the Americas cup, but if they do run with them then I hope that there are some good crashes :D
They tried foiles on windsurfers but they were allot slower than normal windsurfers. Maybe foils scale up well?
Certanly looks fast
from here
http://sumneros.com/2012/06/20/june-update/
After some instruction, Jimmy handed me the tiller extension and let me steer. It was AMAZING! I couldn’t believe it. I drove the AC45 for about 45 minutes. When I was steering the boat, it got up to 20 knots. When I got back on the chase boat the AC45 got up to 34 knots, the max speed for the day.
So you saying that they are photoshopped?
Pretty good job. I suppose the bulge at the base of the rig is photo shopped as well??
Certanly looks fast
I think maybe that was because when a windsufer is going fast it is barely touching the water anyway.
