DrWatson 382 Posted October 29, 2020 Share Posted October 29, 2020 Anyone bought any corten steel lately? Just wondering what a good price for 4mm and 5mm sheets 2.5x1.25 would look like? Quote Link to post Share on other sites
idlerboat 116 Posted November 5, 2020 Share Posted November 5, 2020 Quote Do you need flat ? lots or little ? ( shipping containers are cor 10) I dont have a price but know that it has come down in price because people are laser cutting it and making all sorts of outdoor stuff with the "rusty look". Quote Link to post Share on other sites
TimB 7 Posted November 5, 2020 Share Posted November 5, 2020 Don't know about current price, talk to your local steel supplier. Price is very much determined by quantity also. But note that in NZ anyway, is more likely to be 1.2 x 2.4 or 3.6m and possibly even a soft conversion from 3/16, 1/4, 5/16 inch thickness. .cheers Tb Quote Link to post Share on other sites
wheels 544 Posted November 6, 2020 Share Posted November 6, 2020 Do you want Corten because you want a rusty look? or are you considering it for tensile strength. If the look, then you could consider other cheaper steels and then coat it. There are now coatings that do the same thing, but better. Creating a rusty coating that then acts as a barrier to further corrosion and thus keeps the steel protected for much longer than just bare Corten steel is. Quote Link to post Share on other sites
syohana 39 Posted November 13, 2020 Share Posted November 13, 2020 I've heard of rod rigging but steel sheets sound a bit heavy. How do you get them around the winch? 1 Quote Link to post Share on other sites
LBD 186 Posted November 14, 2020 Share Posted November 14, 2020 On 13/11/2020 at 2:02 PM, syohana said: I've heard of rod rigging but steel sheets sound a bit heavy. How do you get them around the winch? Huh?...Oh I get you...bit droll.... AS well as being higher tensile, corten is also more corrosion resistant than mild steel, so it has a couple of things gong for it.... difficulty to work with and some what specialty welding requirements, count against it Quote Link to post Share on other sites
DrWatson 382 Posted November 16, 2020 Author Share Posted November 16, 2020 On 6/11/2020 at 11:18 PM, wheels said: Do you want Corten because you want a rusty look? or are you considering it for tensile strength. If the look, then you could consider other cheaper steels and then coat it. There are now coatings that do the same thing, but better. Creating a rusty coating that then acts as a barrier to further corrosion and thus keeps the steel protected for much longer than just bare Corten steel is. Yeah, looking at using it for cladding on some parts of a house design... On 5/11/2020 at 9:18 PM, TimB said: Don't know about current price, talk to your local steel supplier. Price is very much determined by quantity also. But note that in NZ anyway, is more likely to be 1.2 x 2.4 or 3.6m and possibly even a soft conversion from 3/16, 1/4, 5/16 inch thickness. .cheers Tb Cheers TimB. understood. Working with the sheet sizes available to minimise wastage is also an important point. Quote Link to post Share on other sites
